Cattler's Avatar
Porsche Crest Confirm turbo vs. "regular" lower valve covers
OK, I've searched and looked at about a million photos this morning, but only saw photos of turbo lower valve covers. In cleaning the lower engine I discovered a leak from the lower leading edge of the right lower valve cover. Its caused a small puddle to build on the heat exchanger.
I think these are turbo valve covers given the design and similarity to what others have posted. Can anyone confirm? (If so, its a rare stroke of PO good luck)
Would be good to have a side by side of turbo vs. "regular" covers--would appreciate someone posting a shot of a "regular" cover as well.
Here's what I have (note from the left side of the car):
This is from a thread I found with a photo of a turbo valve cover:
Thanks,
Dave
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 01-03-2015, 07:31 AM
Josh D's Avatar
Those are turbo. Became standard lower valve cover on '80 normally aspirated engines.
Old 01-03-2015, 07:42 AM
Drisump's Avatar
Yes they are. The stock items in a regular car are basically without the strengthening webs that help retain rigidity. Normally these don't leak between valve adjustments, so if you are replacing the gasket you might consider doing a valve adjustment at the same time. I would also check for cracks once off. Cheers
Old 01-03-2015, 07:44 AM
VFR750's Avatar
Observing the rust on the nuts; I would guess the cover has not been off in a long time. Time for a new gasket.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 01-03-2015, 07:48 AM
Cattler's Avatar
Unfortunately, no. They supposedly were removed and a valve adjustment done about 15-20k miles ago.
Old 01-03-2015, 10:00 AM
VFR750's Avatar
One of the things I noticed on my engine was a build up of gasket material on the mating surfaces. That and some corrosion made for uneven sealing surfaces. Both the cam housing and the cover itself.
The next time the cover comes off you might try to check the valve covers for flatness. I used a single edge razor blade to scrape the sealing surfaces, and found they stopped weaping. You just have to be careful not to gouge the surfaces with the razor blade.
But you may also have a problem with leaking rocker shafts, which can look like a leaking lower cover.
Mike
Old 01-03-2015, 10:08 AM
muck-raker
kidrock's Avatar
if and when you decide to replace the valve cover gaskets, replace them with the black gaskets that have the silicone bead on them...they work best. Also, new Nylock nuts and aluminum crush washers are a *must*. Be sure not to overtighten, just a nice snug. IIRC, 8-9 foot pounds of torque.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-03-2015, 10:39 AM
Cattler's Avatar
Porsche Crest
Thanks--just ordered new gaskets, washers, and nuts. Saw another thread saying that I can jack up the car (tilt in one direction at a time) and not drain all of the (recently changed) oil out when replacing the valve cover gaskets. True? Anyone done this?
Thanks,
Dave
Old 01-03-2015, 11:08 AM
I just recently adjusted valves on my 2.7 trying the "tilt method", but still found it necessary to drain the engine sump to avoid a huge mess on the floor.
Old 01-03-2015, 11:14 AM
Cattler's Avatar
Thanks--so that worked out to about 3-4 quarts to refill?
Old 01-03-2015, 11:18 AM
did it with no tilt at all and lost about 3 quarts. I believe if you tilt it enough, you will loose less than a quart, if at all.
Old 01-03-2015, 01:03 PM
Drisump's Avatar
15k miles is about the max between valve adjustments that I do. When was the last baseline oil change/ air filter/ distributor and rotor/ plugs and fuel filter tune up? If there is doubt or it's mostly over due, I'd consider base lining the entire maintenance program including a change of transaxle oil and a change of brake fluid. Cheers
Old 01-03-2015, 05:54 PM
Just did a valve adjust on my 3.2 with the car jacked up on one side at a time. Lost very little oil, probably half a cup.
Old 01-04-2015, 06:21 PM
safe's Avatar
You need to start the engine for a few seconds (15-20) before tilting, otherwise there might be a lot of oil in the crankcase (its the nature of the drysump system and might vary from engine to engine).
Magnus
Old 01-05-2015, 12:36 AM
Cattler's Avatar
Porsche Crest
Thanks all. I used the tilt method--warmed up the car (a few minutes), worked one side at a time after lifting and placing that side on a jack stand. I lost next to no oil from either side.
Best,
Dave
Old 01-25-2015, 12:12 PM
