Can these struts be refilled and used
I got hold of some early 911 struts, when i took them apart I discovered that there was no cartridge insert, instead the whole strut was filled with oil and there was an internal damper piston/cylinder insert in the oil bath.
The strut casing acts as the oil reservoir for the damper I am not sure what make of strut they the only number I found was on the steering arm L655.01 with a small logo that I couldn't read. They were very rusty so I have media blasted them and painted them black so this is not the original color. Question: Can I refill with oil or do I need to get a damper insert? If any one has come across this before or can identify the stut it would be appreciated ![]() ![]() ![]()
David Sweden 914 76 912 66 |
I found the same on my car when I did a suspension refresh about 3 years ago. I described the open oil bath damper system to a few people who doubted I knew what I was talking about, both on this forum and also one other. Only useful piece of advice I got was to try motorbike fork oil, which i did. I bought the wrong weight initially and found the strut barely moved when pressed, so change it for one weight lighter and it seemed fine. Sorry I can't remember if it was 10 or 15 weight I used. When if took the car for alignment the garage owner drive it afterwards and asked what front dampers I had on because they felt so nice! One in the eye for the people who didn't believe I had that type of damper in the car.
Long way of saying try 10 or 15 weight fork oil Good luck Ian |
Ian,
Thanks for taking the time, yes I have had the same response a lot of doubting Anyway a few questions if you have the time: Is there a procedure to follow when filling or is it just to pour in the oil? How much oil, fill to top? Did you replace O rings if so what material. Thanks again
No problem, happy to help. There is no procedure for filling, just pour in the oil and slowly insert the damper. Only thing I did once the damper was in was to exercise it slowly to tease any air out. When I stripped mine for some reason I kept the old oil and so knew roughly how much to put back in, although I had no way of knowing it was the right amount. All I did was put the same amount of new oil back in. Sorry, but you are going to have to guess. I would go for a little too much rather than not enough for obvious reasons.
I didn't replace the seal as it doesn't do too much and seemed in ok condition, it just keeps muck out really. Hope this helps Ian |
Thanks Ian,
Appreciate your help
Was the internal piston insert sealed?
My 73 had I've struts that had an insert like the one pictured. When I removed the strut, a very nasty oil spilled out. Sounds like a Boge strut and the oil is used to cool the strut by helping conduct the heat to the housing. |
Not sure if this helps... But I just pulled out the exact inserts from my 1980 RoW SC. I Replaced them with a Koni insert. After getting the old oil out first.
My guess is they are the original open bath style? I was keen to try adding fresh oil to see if it would bring them back to life, but already had the Koni's on hand... |
Hope this clears it up Ian |
