911SC Tire Size (16x6, 16x7)?
I have a 1981 911SC and am considering purchasing some new tires.
I was wondering if it'd be possible to run, on the stock (16x6, 16x7) setup:
225/45-16 on the front
245/45-16 in the rear
Anyone have any experience with these tire sizes?
Thanks in advance,
Steven
Old 10-28-2014, 09:13 PM
Rescuer of old cars
Arne2's Avatar
Both of those sizes are too wide for the respective wheels. Check the tire makers specs - the 225/45 show a minimum wheel width of 7.0" (max of 8.5"), the 245/45 are 7.5" minimum (max 9.0").
Even if you can find a shop that will mount them on your too-narrow rims, the performance when pinched down that way will be lacking, the tread will tend to crown and you'll only be running on the center.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-28-2014, 09:26 PM
Originally Posted by Arne2 View Post
Both of those sizes are too wide for the respective wheels. Check the tire makers specs - the 225/45 show a minimum wheel width of 7.0", the 245/45 are 8.0" minimum.
That's what I figured but thought I'd ask.
Reason is, I currently have the stock 6'' and 7'' set-up but would like to eventually move to 7'' and 8'', which those tire sizes would be perfect for. So, was trying to see if a single set of tires could work for both sets of wheels, making me only have to buy once (for tires).
Thanks!
Old 10-28-2014, 09:28 PM
Rescuer of old cars
Arne2's Avatar
Well, the stock 205/55 and 225/50 will fit fine on either 6 & 7 or 7 & 8. Not many tire choices available in 245/45 either.
2018 718 Cayman 2.0
Old 10-28-2014, 09:32 PM
I think the stocks will look a little skinny on the 7/8'' set up.
I was looking at the Toyo R888.
Old 10-28-2014, 09:45 PM
Rescuer of old cars
Arne2's Avatar
You might be surprised. Lots of people run stock sizes on 7 & 8". Far more than run wider sizes.
2018 718 Cayman 2.0
Old 10-28-2014, 10:11 PM
shipfaced's Avatar
I run stock tire sizes on 7 & 8's and they look perfect, in fact, the stock tire size is the correct tire size for 7 & 8's. Have no idea why they squeezed the stock tire sizes on the too-narrow 6 & 7's.
Old 10-29-2014, 06:27 AM
Agreed. When looking at the stock set-up (6 & 7), the rims definitely look too skinny for the stock tire sizes. OTOH, all that extra rubber on the sides might help protect against curb rashes?
Old 10-29-2014, 07:43 AM
Rescuer of old cars
Arne2's Avatar
Yes, the small rims are too narrow for best performance. I suspect Porsche spec'd those sizes for the non-turbos back in '78 when the only tire choice was the P7, which had a (justified) reputation for being harsh riding. The narrower wheels tend to lessen that a bit.
And yes, the narrow wheels are much less prone to curb rash. My originals still don't have any.
2018 718 Cayman 2.0
Old 10-29-2014, 08:27 AM
Hilbilly Deluxe
emcon5's Avatar
Thanks in advance,
Steven
I ran those sizes on 7&8" BBS, (well, 225/50-16 in front) and they worked fine with some fender rolling.
I gave up and switched back to stock sizes after the 245/45-16 street tires all but dried up.
The only options last time I looked were DOT-R and the super high end "Extreme Performance summer" tires, neither of which are all that useful to me on a car driven year round in all conditions. I also have no use for a street tire with a tread-wear number under ~200.
911 wears tires pretty fast as is, I see no reason to accelerate that with an overly soft tire for some minor performance increase that I will never see on the street.
82 911SC Coupe
GTI Cup #43
Old 10-29-2014, 08:38 AM
