Discseven's Avatar
Bye-bye 245 / 45 / 16... Hello noob alignment
245 / 45 / 16 nonsense is done. I know... they're still available IF you want to pay a small ransom. Screw that. For amusement, am going to run the most economical alternative (I can find) for 8" front, 9" rear Fuchs... we'll see how economy performs over time. And... because I can't get a "professional" alignment so tires wear evenly, will dive into alignment having never done it before. Am posting to get input on how to make alignment adjustments. First, some background for you...
Tires
Shopped online... TireRack, TireThis, TireThat.... problem is once shipping, balance and install is added... online's no longer an economical road (as I priced it.) Alternative size am going with is 205 / 55 and 245 / 55. Fronts = $62 each. Rear = $82. Installed total = $371. ZR rated (149+ mph.) Some have put 225 / 45 on rear---now I'm wishing I had the guys load that up to take a look.
Installed
If you're highly sensitive to 911 dimensional relations, DON'T DO THIS --- you won't like it. Fronts are close to 1/2" larger diameter. Rears, 3/4" larger. So my lower... has just been raised 1/4" F... 3/8" R. Remember, tires are only a test. Real mission on hand is DIY alignment. Am covering tires as I imagine others may be thinking over 245 / 45 alternatives. (Good to bring your own stubby tire valves to shop or you can end up with way-too-longs.)
Front = 8 x 16 Rear = 9 x 16
Inside tire wear = standard option that came with this car. Fronts have always worn out leaving good rubber on the outsides. Sometimes both front and back have done same. Regarding front, I've been told "toe is set right but camber will simply not go any more positive." (If that's the case... how bout compensating with toe?) Below is front driver's side tire. And alignment was done supposedly by professionals with the latest high tech equip.
Rears did OK this time around. Still... they're wearing on inside... and I'm guilty of too high pressure. Am dumping rears early only because size change is front-to-rear related.
Alignment
Toe, camber, caster... I understand principles. But am total noob where making adjustments is concerned. Thought "string theory" was interesting approach but from what I've heard, it's a lengthy set up. So... to check track, got $19 laser level from Harbor F. For toe, am going with "under C" method I picked up from Peter Bull in Sweden. TY Pete. His photos...
A look at my strut tops.
As I know it, front-end toe and camber is relatively simple. Rear end... that's complete mystery to me. Not sure I really care about caster---steers fine. Am looking forward to front & rear adjustment input from you guys before putting a wrench to this. TY
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 09-23-2014, 12:22 PM
I am all for do-it-yourself and I know some folks get decent results with home alignment.
My question is why can't you get a pro to align the car with an alignment rack and get good tire wear? There must be someone in Miami that can do it.
When I did my suspension rubber bushing replacement and tie-rods and shocks and so on I did a home alignment and got it pretty close. I drove it with the old tires for a few hundred miles and then had the pro do it with the proper tools, AKA an computer and laser on the alignment rack. My alignment was pretty darn close.
Good Luck.
Old 09-23-2014, 12:31 PM
Checked out
McLovin's Avatar
How wide are your rear wheels? (They look like 16x8, but the pics are too small to be sure)
If you're going cheap, why not 225/50 16? That's what the factory used, it is the exact right height, looks right, etc.
Old 09-23-2014, 12:54 PM
wwest's Avatar
2 points to make...
1. Alignment to factory specification makes the steering to sensitive, constant attention required to stay centered in the lane. Tried several alignments, shops, before being advised that factory alignment was more for track use, constant attention is expected. Was advised that if I wished to drive relaxed the shop would deviate from the factory specs.
Can put you in touch with my shop and maybe they will be willing to share their trade secrets.
2.,,,NOISE!
I always peruse Tire Racks customer reviews in an attempt to find the quietest tires that also fit the other desirable parameters. Sometimes successful, sometimes not.
Most times I have found that "quiet" tires only remain so for 8-10,000 miles.
Had one tire manufacturer that acknowledged that my 8,000 mile tire set was so loud that they not only refunded my cost, they contributed an equal amount to my favorite charity, Seattle Children's Hospital.
Tires are still in storage if anyone is interested.
Old 09-23-2014, 01:21 PM
Elombard's Avatar
Do you have the ray scrugs alignment pamphlet? it will walk you through the rear. Its time consuming but doable. I think some one has posted a scan of it on pelican if you search.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-23-2014, 01:25 PM
keep in mind that your larger diameter rear wheels will cause your car's gearing to become taller, which could affect its perceived performance.
My mechanic in Denver (Jim at Eisenbud's) "solved" the problem I've had with inside front tire wear by slightly bending the front struts (apparently my front suspension was at adjustment limits too). Apparently a common solution for them and I've seen MUCH more even front tire wear since then with no perceived effect on stability/steering effort/etc.
Old 09-23-2014, 01:42 PM
Discseven's Avatar
Good Luck.
Would really like to know a place where I can go and pay for an alignment that results in even tire wear. But I've been down that road and haven't found anyone. Now happens to be a time when I can invest myself in the experience of understanding what's going on... and with guys like you who have done it before, am hoping you'll share tips & tricks to help me along in this challenge.
Karl ~~~
Old 09-23-2014, 02:41 PM
Discseven's Avatar
Front = 8 x 16. Rear 9 x 16. Yeah... was told about 225, and should have had guys mount one on the car. Just thought 225 was too narrow. Seems like just shy of an inch narrower. What am I missing here?
Karl ~~~
Old 09-23-2014, 02:48 PM
Bill Verburg's Avatar
It's a real degradation
here's a comparison of 245/45 vs 255/5o x16 on a US 3.2 Carera
I hope the op made a typo and is using 255/50 not 255/55, which would be worse yet
Bill Verburg
Old 09-23-2014, 02:50 PM
Discseven's Avatar
Originally Posted by wwest View Post
2 points to make...
2.,,,NOISE!
Would like to call them. Pls PM me their number and who I should speak with. TY Will. LOL on quiet. That is a concern after I get the car set up to make them last!
What size are they? I might be interested.
Very nice on charity
Karl ~~~
Old 09-23-2014, 02:53 PM
Discseven's Avatar
I have email for Scruggs... have not contacted him yet for it. Will look for scan. TY Erik
Karl ~~~
Old 09-23-2014, 02:55 PM
Discseven's Avatar
Interesting on gearing getting taller. Never considered that. TY. Do you know if your struts were bent to go more positive camber Darrin?
Karl ~~~
Old 09-23-2014, 02:58 PM
Discseven's Avatar
TY for diagram. Rear is 245 / 55. Without thinking about effect of increased diameter, surly I've self adjusted way I drive to compensate to a degree. Will now apply a more studied sense to performance and comment later on this.
Karl ~~~
Old 09-23-2014, 03:05 PM
I would presume that was the case --
Old 09-23-2014, 03:18 PM
Setting caster and camber is pretty easy. I Went and bought a digital level at home depot, 80$ or so. Setting camber was done by simply placing it against the rim, and adjusting. Easy as can be.
Castor was done by setting it against the front of the strut, with the wheel removed. Pretty easy also.
Toe, not so easy...
Bo
Old 09-23-2014, 03:41 PM
More info please. Do you mean he bent the spindle upwards? That would make sense, though I am dying to know how that was done. Many folks could benefit from a method to tweak the spindle a half degree or so. But how? Short of hitting a pothole at 60mph ... .
Bo
Old 09-23-2014, 03:43 PM
armand80sc's Avatar
How have they attempted to adjusted the camber in the past when there is still the tar stuff on the strut top mounts? I suspect the store didnt even try, just like in my case.
Old 09-23-2014, 03:50 PM
Bo
Unfortunately, I didn't personally witness what they did -- you might want to try calling them -- Eisenbuds-Fine Service of Porsche, Mercedes, Audi and VW 303.825.0322
Old 09-23-2014, 03:52 PM
Discseven's Avatar
Setting caster and camber is pretty easy. I ENT and bought a digital level at home depot, 80$ or so. Setting camber was done by simply placing it against the rim, and adjusting. Easy as can be.
Toe, not so easy...
Bo
HA! And I thought toe was the easiest to adjust Bo. This is going to be interesting expidition.
Karl ~~~
Old 09-23-2014, 04:08 PM
Am in process of cleaning tar off passenger's strut. But driver's... you can see it has been moved. Since alignment place has not moved tops out to touch car, I suspect the way they are is as far as they go. But we'll have to see about that. If it is, other means to a good end will be sought. Bending the struts is already on the table.
How do you plan to bend the struts? Adjustable camber plates are available.
Bo
Old 09-23-2014, 04:15 PM
