-   -   lowering question (http://forums.pelicanparts.com/porsche-911-technical-forum/83117-lowering-question.html)
Mike M 10-06-2002 07:53 AM
lowering question
Quick question....does anyone know how far you will lower the front end with one full turn of the adjuster? I want to try something and have the ability to put it back to the starting point.
Thanks as always...
Wil Ferch 10-06-2002 08:43 AM
Hi:
Guys...take this to the bank:
I revolution causes a 1/4" height change. As you're on your back looking up ( "worm's eye" view)....clockwise turn raises car...ccw lowers car.
Careful...lowering increases toe-OUT. Small adjustments in height won't make a big difference ( say...1/4 to 1/2" height change)...but if you're going for 1" height change or more...check toe.
--- Wil Ferch
:cool:
Mike M 10-06-2002 08:58 AM
re:lowering
Will...thanks alot,that's exactly what I was looking for...
Cheers
87turbolook911 10-08-2002 06:25 AM
What and where
1 Attachment(s)
Does anyone have a picture of the adjuster? Can I simply jack up the car and turn it CCW two revoltions to lower the front of my car .5 inch? Right now my car sits 26" front and 25.5 rear. I just wanted to even the car out.
Superman 10-08-2002 08:24 AM
The front wheel well of an automobile is larger than the rear well. This is because the front wheels move around a lot more. So, your car will still have a 'nose down' attitude if your front fender lip is a half-inch higher than the rear. A half-inch difference is the popular figure.
Fassi 04-12-2003 09:36 PM
Could someone please post a pic indicating which screw is the adjuster. Thanks.
Jocke 04-13-2003 12:52 AM
I post a pic in a thread before with nearly the same question, here it is: http://forums.pelicanparts.com/porsche-911-technical-forum/77393-adjustment-torision-bars-right-way.html
/Jocke
Fassi 04-13-2003 06:09 PM
Thank you very much
