-   -   '73 911E front rotor question (http://forums.pelicanparts.com/porsche-911-technical-forum/8313-73-911e-front-rotor-question.html)
tmctguer 09-17-2001 07:46 PM
i'm about to begin a front brake job on my '73 911E. i will be replacing pads, turning the rotors, and bleeding the brakes to replace the fluid.
i read the shop manual (imagine that !!) and found that the min/max front rotor thickness is 18mm/20mm. my front rotors are now at 19mm and have a few minor ridges in them.
two questions:
1). what is the likelyhood that more than 1mm will have to be removed from the rotors when they are turned?
2). should i turn them and put new pads in, or should i splurge now and replace the rotors?
3). what brake pads are recommended for 90% street, 10% track use?
Evans, Marv 09-17-2001 08:30 PM
I doubt that turning the rotors would take off as much as a milimeter, so I would imagine it would be OK to have them turned. But, you will have to replace them next time around. However, new rotors aren't that expensive & if you're inclined to replace those you have now, that would be a good idea too. It's about 6 on way & half a dozen the other. Somebody else can comment on the pads.
Marv Evans
'72 911E
Matt Smith 09-17-2001 09:26 PM
Buy new ones. I turned my present rotors at a similar level of wear and they lasted about 3 months before warping again. for the cost and hassle I'd go for new next time. Still stop ok though.
'72 911 TE
Bruno Lavion 09-18-2001 08:00 AM
I second that,
Just buy replacement rotors, overall with new pads, you will have the best results. I did the entire job myself 3 years ago, it's quite simple.
Bruno Lavion
73 911E
Steve F 09-18-2001 09:32 AM
Don't throw out the old ones.If you do ,throw them my way, http://www.pelicanparts.com/ultimate/biggrin.gifthat might work out as an upgrade for my little ol'e 912 someday.Your only 35 miles away,and I'll trade you a 12 pack for to boot! http://www.pelicanparts.com/support/smileys/wat6.gif
1967 912 "in progress"
Now ,with a 2.0 T4 to play with!
