Yea, they turn on when you pull up the levers.
It's a small project. 3 screws to remove the cover. Fuse probably blown (10a) Just remove the break the fan free. Mine was stuck from years of non-use. The hardest part is replacing the cover. lining up the holes for the screw. I use a coat hanger to line up the screw hole. |
| All times are GMT -8. The time now is 03:48 PM. |
