| Targalid |
09-26-2014 11:53 AM |
Distributor Advance Instead of Retard?
I cleaned my 1976 911S distributor and reset the total advance per Gunter's distributor maintenance thread. I have the Bosch distributor with vacuum retard of 5 degrees at idle. Total advance is set at 33 degrees at 6K rpm. The 5 degree retard was required by California pollution regulations at the time. Later distributors have a 5 degree advance at idle. Under load, I should have 33 degrees advance. When cruising, with less throttle, I should have 28 degrees total advance because of the vacuum retard fixture, correct? Distributors with the 5 degree advance fixture should have 33 degrees advance under load but cruise at 33 plus 5 or 38 degrees total advance. This is better for both performance and engine temperatures isn't it? So, my question: can the retard mechanism, held by two screws to the side of the distributor, which rotates the timing plate, be replaced by one that advances the timing 5 degrees? Or, do I look for a complete distributor that has vacuum advance instead of vacuum retard?
