83 SC
tkmoore's Avatar
Gas smell inside my 83 SC
Need some guidance. The inside passenger compartment of my 83 SC has a never ending gasoline smell. Smell is worse when the tank is full but never really goes away completely. Any ideas on the cause and fix?
Thanks,
Tim
Old 09-13-2014, 06:34 PM
Thanks,
Tim
Many threads on this. Off the top of my head, the most common suspects are: gas cap, gas sender seal, hoses or connections for the evaporative emissions inside the trunk, vapor hose or box behind the gauges, vapor/gas overflow hose or collection box behind the left headlight, fuel pump/hoses and connections. In short, check every hose, along its entire length, that you find connected to the tank and filler neck.
Give the above a close inspection as a start.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-13-2014, 07:13 PM
Without seeing it, I'd say it's the hoses from the evaporative emissions system. Replace them (I did) and the smell goes away. Just remember to disconnect the battery before you begin.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 09-13-2014, 07:17 PM
83 SC
tkmoore's Avatar
Don, where did you get the correct hoses.Tim
Old 09-13-2014, 07:20 PM
AJ's 911's Avatar
Check to see if your carbon filter canister hoses are detached or if it was removed. It is located under the passenger side rear wheel well closer to the door.
AJ
84 911 Targa, 76 911 Targa, 2014 Cayman S, 77 280z
Old 09-13-2014, 07:25 PM
Hoses are available from Pelican, by the meter. You can look up the hoses in the PET and it will tell you their internal diameter, and length, in millimeters. This is worth getting right because you don't want a sloppy fitting hose. I'm replacing all my fuel and evap hoses and just got my first order from Pelican. The cloth covered hoses they sell are nice quality and as-original. Best regards, John in CT.
Old 09-14-2014, 03:38 PM
You can source them from our host. I used a local repair shop who carries this type material.
Don Newton
Old 09-14-2014, 10:38 PM
I'd also suggest a new gasket for the fuel sender. My '83 SC had similar issue and the new gasket solved the problem. To replace the hoses already mentioned is a good idea "while you're in there" as well.
Old 09-15-2014, 03:15 AM
Dave Colangelo's Avatar
I had this problem recently and it turned out to be the small piece of hose that goes from the tank to the pump. Maybe 4 inches of hose. Luckily I caught it before it gave out completely. The house had simply disintegrated to the point where it was leaking vapors and a bit of fluid as well. Its worth checking all rubber that is involved with the gas system.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 09-15-2014, 08:42 AM
Remember to disconnect the battery before you begin the repair process! Any spark you create could be "illuminating".
Don Newton
Old 09-15-2014, 09:08 AM
Look for any leak around fuel pump
Old 09-15-2014, 09:11 AM
gtrp's Avatar
Ever figure it out tkmoore?
I just filled up my 911sc to about 50% and now my cabin also smells like gas but I cannot locate any fuel leaks and notice no major drops in my fuel level..
Old 09-23-2014, 09:52 AM
theiceman's Avatar
Did you check all the things listed in this thread ? i doubt there is one magic bullet that fixes al.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-23-2014, 09:59 AM
gtrp's Avatar
Checking it out myself this evening but I am new to getting hands on. This will be fun.
My car has a roll cage and Recaro seats, so that could be the culprit since there is no smell from the trunk or engine bay.
Widebody 911SC
Old 09-23-2014, 11:14 AM
PooShee's Avatar
Weird, I filled mine up the other day and the stupid gas pump didn't shut of and overflowed...the over flow drain the body panel drained it all out. i looked n the trunk, interior etc to see if any overflowed an got on anything..how wants a fire...
No my gas gauge is at 1/2 (thought it was over filled!!) and I have a faint smell of gas in the cabin when it sits o/n
At this point I am assuming it is the residue in the overflow gutter and just waiting it out.
Old 09-23-2014, 11:57 AM
TheSt|G's Avatar
You can always pour some water in there to wash it out.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 09-23-2014, 01:21 PM
Dueller's Avatar
Don't forget the o-ring on gas cap.
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 09-23-2014, 05:24 PM
Anyone ever try one of these things. After about 3 hours in an enclosed garage, I get a gas smell, but have not been able to locate the source. Open up the garage door, air out the garage, close up, 3 or so hours later, smell is back.
SALE - UEi Combustible Gas Leak Detector CD100A - $123.69 - - GasSniffer.com
Who, What, When, Where, Why and How.
Old 09-23-2014, 09:18 PM
PooShee's Avatar
oh, damn. Thats brilliant.
Thank you master.
Sincerely,
Grasshopper
(seriously, not being facetious. I was just gonna wait it out, already going away. If not gone by weekend...the whole car is gonna get a washing)
Old 09-23-2014, 09:51 PM
gtrp's Avatar
I let my car sit for 48 hours and have a nice small puddle of fuel on the floor of my garage. Seems to be coming from the front right of the porsche. Still no free evening to start tearing things apart...
Widebody 911SC
Old 09-25-2014, 07:00 AM
