What is this
Hello guys,
Can anyone tell me what the electric cable is at the back (right) of the picture - on the hat shelf / parcel shelf ?
It is not connected to anything in my car (1987 3.2 coupe).
Many thanks,
Kurt
Old 10-13-2014, 07:05 AM
That's the cable for the rear window defogger. It's supposed to be routed inside the groove of the window seal, through holes in the seal along the vertical edges, and connect to the terminals for the electric defoggers. If your rear window has been replaced and does not have the defogging circuit, or the seal replaced, it is often left out due to the hassle of trying to connect through the seal.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-13-2014, 07:10 AM
Taking it apart is easy
Jerome74911S's Avatar
Same answer as above, but my third brake light wire is routed through that corner, too.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 10-13-2014, 07:12 AM
What is this
Many thanks.
This does make sense. The rear window seals were replaced by the previous owner.
No third brake light installed, so it must have been too much trouble to rewire the window defogger.
Case closed !
Kurt
Old 10-13-2014, 07:20 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by kvdven View Post
Many thanks.
Case closed !
Kurt
FWIW - I replaced my seal. Need to cut notches in the new seal to match with the old seal for where wires pass through seal to the connection points up the window. PITA.
1981 911SC Targa
Old 10-13-2014, 12:39 PM
