-   -   Relay Question (http://forums.pelicanparts.com/porsche-911-technical-forum/832241-relay-question.html)
Dreamer52 10-01-2014 05:28 PM
Relay Question
I have all red relays from the PO in my '89 Targa. Is there a problem having all red relays or should I replace all but fuel pump relay?
db_cooper 10-01-2014 06:34 PM
No problem..the red relays have a diode built into the coil to allow a path for current when the relay is switched. This prevents voltage spikes. The black relays do not have the diode.
