-   -   Trying to identify engine (http://forums.pelicanparts.com/porsche-911-technical-forum/832425-trying-identify-engine.html)
ratex 10-03-2014 12:54 AM
Good day all from sunny Cape Town South Africa.
I am trying to identify a 911 engine serial number 6113008. I need the date and specs if possible. This engine is fitted in a 356SC with a 901 gearbox.
Many thanks!!
19-911-65 10-03-2014 03:08 AM
From the "Red Book"
1971 911T
Eng. SN range: 6110001-6113475
Type: 911/03
Bore: 84mm
Stroke: 66mm
2.2L; 2195cc
Compression Ratio: 8.6:1
Zenith 40 carbs
Intake: 46mm
Exhaust: 40mm
125 HP @ 5800RPM
130 FP Torque @4200RPM
ratex 10-03-2014 05:31 AM
Many thanks for the info - just what I need.
pors1968 10-03-2014 06:16 AM
Must be a happy 356C
poorsha 10-03-2014 06:43 AM
Does that make it a 956?
19-911-65 10-03-2014 12:46 PM
You are welcome...sounds like a fun ride!
