RFP RFP is online now
RFP's Avatar
Any DIY 'Tips' on recovering door pockets? (1987)
I have a pair of new ABS door pockets on their way to me from these folks https://sites.google.com/site/911porschedoorpockets/home . I already have the Sliverknit/vinyl recovering kit from Bob at APPBIZ.
Now, all I have to do is put the two together and do it properly... looks as if it could be a bit tedious!
So, even as a newbie, I am amazed at the knowledge and experience here at Pelican and am hoping that someone has [successfully] done this little project and can offer suggestions... in as much detail as possible (!)
I am also interested in knowing just what adhesive would be best, and would provide long-term 'holding power.'
All the best,
Rob
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 10-02-2014, 06:08 AM
Drisump's Avatar
I've had my ABS pockets for a couple of years and have yet to install them for that very reason....they sell you the pocket and the carpeting but in my case, gave me NO information of how to do it. I'm thinking that the whole works will have to go to an upholstery shop. I'll be curious to see what responses you may get. Cheers
Old 10-02-2014, 06:25 AM
Drisump's Avatar
I should've mentioned that my ABS pockets and carpeting was not from (at least directly from) the link that was in your post.
Old 10-02-2014, 06:44 AM
I think I am also going to buy these same pockets from 60sLincolns, but wondered if they were worth $300 when I can get new fiberglass ones for less than $200. Why did you ultimately choose ABS over FG?
I am planning on at least getting a quote from an upholstery shop before trying it myself.
Old 10-02-2014, 11:45 AM
RFP's Avatar
Kerry...
I read all of the eBay feedback on the supplier of the ABS pockets; it was all positive. On the other hand, I noticed several posts on this Forum about the fiberglass pockets needing considerable "fitting" in order for them to work well. I'm really not interested in having to "rework" new stuff to make it fit my Porsche correctly!
Rob
Old 10-02-2014, 12:44 PM
RFP's Avatar
Wow, Dri... I really admire your patience! When the pockets arrive, I'll be diving in right away. Absent any better advice, I'll start with the very top edges (where the vinyl folds over the tops of the pockets) and work from there. I am hoping to be able to glue a narrow band of the vinyl completely across the tops of the pockets first; then proceed to gluing/forming the carpet once that all-important top edge is securely in place.
I'm thinking I'll use contact cement for those first attachments to the pockets and then use spray adhesive (3M 74 Orange) to affix the carpet part. Wish me luck... of course, I'd rather have skill!
Rob
Old 10-02-2014, 12:49 PM
bill's911's Avatar
As you posted ... start at the top of the pocket where the vinyl starts so that you can hide it as much as possible. I clipped mine using alligator clips (paper supply type) to dry fit. When I was certain the dry fit lined up correctly, I started the trimming and glue. Worked great! The alligator clips are also good for holding the lower edge while the glue drys. Post pics
Old 10-02-2014, 02:56 PM
schulr's Avatar
Send a message via Yahoo to schulr
take a look at this video on a carpet install. It covers the entire car and is in three parts. I believe the door pockets are in part 3. I'm currently doing mine but have not started the pockets yet. Hope this helps. Installation instructions interior carpet set Porsche 911 '74-'89 (part 1 of 3) - YouTube
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 10-02-2014, 04:15 PM
Brew Master
cabmandone's Avatar
I think the product I used was 3M Foam Fast. I'll check tomorrow and see if I can post a pic of the can.
Old 10-02-2014, 04:50 PM
RFP's Avatar
I would REALLY appreciate that!
Thanks!
R
Old 10-02-2014, 04:53 PM
RFP's Avatar
Thanks a million... I "thought" that I searched YouTube pretty good... obviously, nope!
Thanks again...
R
Old 10-02-2014, 04:55 PM
schulr's Avatar
its 3M 74 which every one uses. About $25/can.
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 10-02-2014, 06:20 PM
Check out GeorgeK's cab thread:
1984 Cabrio - Long Term Project
Pretty sure I recall him doing them.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 10-02-2014, 10:59 PM
Brew Master
cabmandone's Avatar
Spray adhesive
Here's what I used. I did use staples on the inside of the pocket for the vinyl. My pockets had staples so I assumed that was factory and put staples back on the inside of the pockets. You want the adhesive to tack and then apply the fabric. I didn't apply to the entire piece but rather lifted the fabric and sprayed the adhesive on then checked fit and worked my way down to the bottom of the pocket. I didn't do a great job on the vinyl but it turned out better than what I had before. Just be patient and take your time. Have either a good sharp pair of scissors or an exacto knife because you'll have to do some cutting at the bottom of the pocket if I recall correctly.
BTW, I bought my spray adhesive on Ebay for considerably less than anyone else was offering it for. I bought 6 cans for my complete interior job.
Old 10-03-2014, 05:49 AM
