-   -   Weird '84 engine problem (http://forums.pelicanparts.com/porsche-911-technical-forum/832504-weird-84-engine-problem.html)
MikeDL 10-03-2014 12:26 PM
Have gotten nowhere trying to figure out a very strange problem. Two weeks ago, after a heavy rain the night before (which may or may not have anything to do with this), it didn't want to start . It would crank strongly, barely catch, idle fine for 20 seconds, then the rpms would drop, the engine would stumble, then finally it would die. After a while I found that if I could hold the rpms above 2k, the engine would run perfectly; if I let off the pedal it would drop to idle and repeat the above symptoms. Finally, it seemed to go back to idling normally so I tried to drive it. The first few times I came to a stop, the car would stumble and try to die just as I let off the clutch, but that went away in a few minutes. Eventually it seemed totally fine and I drove it normally for about a week.
Then this week the same pattern (yes, another heavy rain) repeated but now the car won't start at all. New behavior though: again it cranks strongly but never tries to fire at all until just as I release the key it will cough gently a couple of times before stopping.
I've replaced the DME relay and fuel filter, checked the distributor cap & rotor, jumpered the fuel pump fuse... Any ideas?
douglas bray 10-03-2014 12:29 PM
Check your distributor cap....Wait, how did I not see your last line.
Any water in your ICV connection?
MikeDL 10-03-2014 12:36 PM
I will take it off, check and clean it. Thanks!
pete3799 10-03-2014 12:42 PM
Spray some WD40 in the cap.
It will remove any moisture in it.
MikeDL 10-03-2014 01:00 PM
ICV was dry. A little sooty, so I cleaned it. No change. The distributor is dry and clean.
Targa Me 10-03-2014 01:04 PM
There may be water in the oil breather hoses. (This happened to my 84)
Remove all the hoses and clean them out.
kidrock 10-03-2014 01:47 PM
I'd be checking for spark and fuel at this point. Possible dead fuel pump.
MikeDL 10-03-2014 02:53 PM
I have fuel to some extent -- not sure if the pressure is right but there is some making it to the injectors. And I know I have some spark, not sure if its intermittent, weak, or mistimed.
RedCoupe 10-03-2014 04:05 PM
If the spark plug wires and connectors are old, they can "leak" electricity to ground when they are damp or it is very humid. When the car is running poorly, particularly if it has just rained, open the engine lid with the engine running in a dark or dimly lit garage. If the wires are leaking it should be visible. Also, I would pull the wires and examine each one for cracks in the insulation and check the resistance on each wire, connector to connector. The correct resistance will vary based on what type of wire you are using, but you will immediately see if one is much different, i.e. infinite resistance or 100k ohms when all the rest are 5-10k.
MikeDL 10-04-2014 12:57 PM
Checked resistance of several spark wires, all seemed good. I pulled a couple of wires and hooked up a spare spark plug, looked like a strong, bright spark.
Pulled the Motronic and cleaned the contacts. Decided to open the box and look for any issues. Saw one trace that looked like it might have corroded or burnt so I bypassed the damaged area. Nothing changed at all.
Looked for water in various hoses (oil, vacuum, etc) and found nothing.
http://forums.pelicanparts.com/uploa...1412456037.jpg
rennworks 10-04-2014 03:40 PM
what is the resistance of the cylinder head temp sensor?
dodger1 10-04-2014 05:37 PM
coil wire
Check the condition and resistance of the coil wire. There is enough voltage to jump a gap in the wire with a plug removed but maybe not in place. Another possibility is moisture or even a crack on/in the coil tower.
RedCoupe 10-05-2014 06:16 AM
What about the AFM? The carbon tracks on these things go bad, and the cars run really poorly then. Whether this could be exacerbated by moisture, I don't know.
VW_NUTT 10-05-2014 06:40 AM
How old are you plug wires? sounds like they are going bad. At night spray them in the dark and you will likely see sparking where you should not. My wires are toasted and the car runs fine when its dry.
MikeDL 10-05-2014 07:20 AM
Went out this AM with the new ideas:
- CHT sensor 4.1k ohms @ 40F
- .3 ohms resistance for the coil wire
- Coil looks good, no cracks or defects to the eye
- AFM resistance (9v test) tracks smoothly as door is manually moved
- Plug wires are about a year old and don't spark in dark on a moist day. Will try spray test when dark
So, after checking these things I tried to start it up and it purred like a kitten. Since the last time I tried, I checked the things above and did nothing else. It is a very cold dry windy morning so if this does have some relationship to moisture, today would be the opposite situation.
MikeDL 10-13-2014 07:25 AM
Rained over the weekend, and I'm back right at the start (or in this case failed to start) with the same symptoms.
techman1 10-13-2014 08:54 AM
I would look real close at the wires for engine sensor. Cyl head temp, both flywheel sensors. (Think there are two)
Reason- I recall a few years ago someone posting same symptoms. Water was getting in the wiring harness for one of the sensors. Look at the wire sheath for all the connectors.
stlrj 10-13-2014 09:02 AM
Now it's time to pop the distributor cap and dry inside the cap and distributor with a blow dryer on high.
Afterwards you'll be scratching your head and wondering why you never thought of that before.
Cheers,
Joe
Nick Triesch 10-13-2014 09:34 AM
I have owned many old VW bugs in the past and this was a common problem after heavy rain. Water just finds a way in .
Hoss911sc 10-13-2014 10:40 AM
FWIW - another possibility is the O2 sensor, especially if its not the 3-wire later version. The fact that the engine runs over 2k rpm could indicate an O2 issue - I had this in my '85 and it took 2 years to figure out. Ran fine dry but similar symptoms to yours when it was very wet. Good Luck
MikeDL 10-22-2014 02:33 AM
Update -- last week (while it was raining frequently) I checked and cleaned all sensor connections, replaced the distributor cap and rotor. No change. Over the weekend it dried out and the car started working fine. I replaced the plugs (the gap had widened a lot) and coil (even though it bench tested fine) -- car continued to run good. Last night it rained all night but the car started just fine this morning. So if this result holds, I'm going to blame the coil.
