-   -   Low Beams Don't work but high beams do (http://forums.pelicanparts.com/porsche-911-technical-forum/832693-low-beams-dont-work-but-high-beams-do.html)
kcf7z 10-05-2014 04:54 AM
I assume this is due to the stalk switch being bad but the symptoms were not exactly what I found for the fixes in my "search" of the technical forum. I read about the contacts being the problem.
Symptoms:
low beams do not come on but fog lights do
high beams work
turn signals are erratic
Car: 79 Euro 930
I am sure this is a repeat, but those with wisdom, please redirect.
toddu 10-05-2014 06:10 AM
Low and high are on separate fuses. Start there.
Todd
mreid 10-05-2014 06:20 AM
Fuse and include an inspection for corrosion in the fuse holder if the fuse is good.
3literpwr 10-05-2014 06:22 AM
Happened to me last week and it was the fuse... Didn't blow, just needed to be reinserted as it was sitting a little wonky.
PorscheAmateur 10-05-2014 07:47 AM
Check the fuse. But it could also be the switch like it was for me. For some reason my lows worked but my Highs didn't.
LakeCleElum 10-05-2014 07:52 AM
An old thread from 2005 is your friend:
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
timmy2 10-05-2014 08:10 AM
If it is just the fuse, you should install the headlight relays.
86 911 Targa 10-05-2014 09:04 AM
Relays.
http://forums.pelicanparts.com/uploa...1412524958.jpg
http://forums.pelicanparts.com/uploa...1412525037.jpg
http://forums.pelicanparts.com/uploa...1412525064.jpg
For our '86
