Tranny lube to use
I'm changing the transmission lube in my 81 targa soon and had this stuff left over from my old corvette
Will this work have you guys used redline ns in your porsches any reviews ![]() |
Banned
Can't go wrong with sepco 201
82 SC Twin Plug 3.2 SS ,46 PMO ![]() |
It's SWEPCO - Southwestern Petroleum Corporation - Southwestern Petroleum Corporation - SWEPCO
abit off center
I use only redline MTL it's 70W80 in all my Mk2,3 and 4's with great results and plan to try it in my Carrera this summer.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
gearhead
Never put Redline in a 915 gearbox. Ever.
Bye, Bye.
I've read bad things about Swepco.
My "very well known" wrench in Seattle recommends Kendall.
Elvis has left the building. Last edited by Scooter; 03-26-2014 at 06:24 PM.. |
So what are you guys using and what weight
'82 SC TL
Redline not recommended as mentioned. One of the best suited for 915 trans. is Kendall NS-MP Hypoid 80W-90 for non LSD or Kendall Special Limited Slip 80W-90 for LSD highly recommended
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered ![]() |
I like and use the Kendall
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
abit off center
Searched redline specs and not recommended with hypoid gears so I guess the Kendall stays in which is a great gear oil
Also our host is selling the redline 75w 90 NS for our transmissions so I'm thinking if their selling it it must work just fine
Shhhh... Uhhh
"Dyin' ain't much of a livin' boy." - Outlaw Josey Wales |
'82 SC TL
Our host sells a lot of parts for "a lot" different makes & models like Audi/VW, BMW etc. (thankfully
'82 SC TL
I should at least mention this is all re. the "Redline Synthetic" type ( NOT good for our 915), however, re. the "non-synthetic Redline" from my pers. experience ( fr. using Swepco & Kendall & older non syn.-Redline ) I would just as well stick with the tried & true Kendall, never had any issues with it.
3+ on Kendall 80w90. Using Swepco 201 gave me poor (slow and stiff) shifts until really warmed up and even then, not a good as Kendall right from cold. A no brainer for my transmission.
Turbo Hooligan
I've used the lucas regular gear oil for years in mine. 2 bottles of 8090 and one of gear stabilizer. Even eliminated the 2nd to 3rd crunch on hurried upshifts that I had with swepco.
D-Zug ![]() |
gearhead
Ok just asking some question as it's my first 911 and I know some of you guys have had these for years and probably know what works best
Sounds like the Kendal is the leader so far |
Fleabit peanut monkey
Pay attention to the exact type of Kendall recommended.
1981 911SC Targa |
