arbita1's Avatar
Replacing front shock inserts
I'm in the middle of replacing my front shock inserts. I have boge struts.
I'm having two problems.
1. I can't get the drivers side stut off of the ball joint pin. I rubber deadblow hammer worked well on the passenger side. But the drivers side won't budge.
2. What is the best way to get the strut cap off? It looks like it needs a special wrench, which i don't have.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-04-2007, 08:58 AM
safe's Avatar
1. As an alternative you can remove the ball joint from the a-arm instead.
2. Pipe wrench or a big channel lock wrench.
Magnus
Old 08-04-2007, 09:28 AM
arbita1's Avatar
I don't have the special tool to remove the ball joint from the A-arm.
I tried a big pair of channel locks. Maybe I'll give the pipe wrench a try. I was also thinking of just bringing them to a shop and having them remove and replace the shock inserts.
But I still have to get that drivers side strut off!!!!!!
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-04-2007, 09:51 AM
safe's Avatar
Sure you do, it's called a pipe wrench
And before you say anything, yes, it's my favorite tool You can also use it to hold the washer when you remove the struts top nut.
Magnus
Old 08-04-2007, 11:14 AM
arbita1's Avatar
New Problem
Ok...so I got the shock out of the strut (the one on the drivers side that I couldn't get off the ball joint). Guess I really didn't need to take it off.
Now I have a new problem!
The old shock is a Koni Red. The new shock I'm installing is the Bilstein Sport (revalved to Smart Racings specs).
The shaft sizes are different diameters. And the gland nut that fit over the Koni's does not fit over the Bilsteins. I bought these Bilsteins used and they did not come with a gland nut.
Is it just a mater of getting the correct gland nut from Bilstein? Or do I have the wrong shocks for my struts. It doesn't seam like there is alot of space left in there for the gland nut once I slide the shocks into the strut.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-04-2007, 11:39 AM
safe's Avatar
I would say you have the wrong shocks. What Bilstein part number have they?
Magnus
Old 08-04-2007, 12:26 PM
arbita1's Avatar
I hope not.
The part number is F4-p36-0113-h003.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-04-2007, 01:06 PM
safe's Avatar
That should be the right part, you probably only need a new gland nut.
Magnus
Old 08-04-2007, 01:44 PM
arbita1's Avatar
I hope so. Guess I'll have to call Bilstein on Monday.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-04-2007, 02:09 PM
PRO Motorsports
Tyson Schmidt's Avatar
The Bilstein-for-Boge inserts use a special top nut that has a seal as well. You'll need these, obviously.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-04-2007, 03:17 PM
michael lang's Avatar
Matt, why don't you just call the people who did the revalving for you. I replaced my old Boges with Bilstein Sports and the flanges came in the box with the new inserts. The people that did the revalving for you may have them sitting on the bench in the shop. If no luck there, call our host, they may have exactly what you need.
mike
Mike
'89 CARRERA
#402
Old 08-04-2007, 04:32 PM
arbita1's Avatar
Mike, I bought the shocks used so I never had the hardware to begin with. I thought the existing stuff I had on my current set up would work.
So after doing some more research, it looks like I do have the right shocks. I just need to get the proper hardware.
One more question....Do the Bilsteins use bump stops? The ones I have on my Konis will not fit due to the shaft size difference. But it doesn't look like the bilsteins for boge inserts even come with them.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-05-2007, 05:29 AM
safe's Avatar
It looks like the Bilstein is shorter, is that true?
Magnus
Old 08-05-2007, 05:39 AM
Regis turd ab user
Matt; Not sure why you removed entire strut to change insert?
In addition to the new gland nuts you'll need, you do not use the triple stack rubber bump stops with Bilsteins, they are built in. If you try use them you won't have enough piston shaft to go up through the mount.
Old 08-05-2007, 06:52 AM
arbita1's Avatar
Because I followed the Bentley manual. I ended up leaving the drivers side in place.
I'm doing a caliper rebuild and replacing the rotors too. So most of that stuff had to come off anyway.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-05-2007, 08:07 AM
Regis turd ab user
Matt; Bentley manual does not apply to my car, 71', but I have read there are some incorrect and unnecssary procedures in it. Most of our normal repair tasks are posted throughout this forum with many practical step savers.
I recently did "all" of the repair (upgrades) you are doing with my struts on the car. Just a thought!
Old 08-05-2007, 11:04 AM
arbita1's Avatar
David - you're right. Bentley has some faults.
I actually am going to have to put the passenger side strut back on the car to open the gland nut. It was easier to do it that way than in a vice.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-05-2007, 03:48 PM
When I did mine, the strut assembly stayed mounted to the car. The Boge insert came out, & the Bilstein Sport insert went in. I used some large Channel locks to get the Boge flange nut off and I used the Bilstein tool to lock down the replacement flange nut that came with the inserts. It turned out to be alot easier than I had anticipated. It looks like the part # for the strut flange tool is MS08/4.
Mike
'89 CARRERA
#402
Old 08-05-2007, 04:23 PM
arbita1's Avatar
Yes it is. The yellow and the red part meet at the same point. However from that point to the top of the threaded shaft, the Bilstein is shorter.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-06-2007, 02:24 AM
safe's Avatar
Good to know its the same in the front.
When I changed from Bilstein HD to Sport (clubsport really) in the rear, the sport was 20 mm shorter.
Magnus
Old 08-06-2007, 02:40 AM
