Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Transmission is off the car. What seals should I get?
"While I'm in there...I want to make sure my trans is all sealed up. I have new motor mounts ready to go. What other seals/plugs/etc should I get while I've got it off the car?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 10-12-2014, 09:53 PM
OsoMoore's Avatar
There are some seals associated with the clutch release lever. Others can give more info on that.
Also be sure to protect the clutch disk and throw-out bearing while the transmission is off.
If you leave the throw-out bearing exposed to water and moisture, it can be damaged. Also be sure to re-grease it as well.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 10-13-2014, 11:34 AM
Under the radar
Trackrash's Avatar
The trans has an input shaft seal, drive flange seals and a shift rod seal.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-13-2014, 01:10 PM
Rennch on YouTube
rennch's Avatar
thanks gordon.
Michael O'Neal -
Old 10-13-2014, 10:54 PM
depending on the trans year I seem to recall you couldn,t replace the input shaft seal without disassembly in early 915 trans. Others would know better.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-14-2014, 07:39 AM
LJ851's Avatar
input shaft seal
shift shaft seal
output shaft seals (2)
diff cover o-ring
There are 3 rubber dust seals in the clutch pivot arm assembly as well. Would be a good time to inspect clutch fork, pivot shaft, pivot shaft bushings.
Old 10-14-2014, 07:47 AM
