Guest
Posts: n/a
Adjusting fit of hood and frunk with shims
Did the factory use shims under the hinges to adjust fitment for the hood and frunk lids? thx
I recall seeing shims on the rear deck lid of my '84.
Kurt |
porsher
hood definitely, i had them on my 86
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
yes.
Tru6 Restoration & Design |
Guest
Posts: n/a
Great - did the factory use washers as shims or some type of body shim? Thanks!
Rectangular shims.
Guest
Posts: n/a
Any idea where to find them? I haven't been able to find a reference to them. thx
I imagine special order. I have a few sets from dismantling cars but am holding onto them. They are rare, I guess get lost easily and then washers are used.
Part # for rear deck spacer is 999.025.098.02, 13A in the PET diagram.
The majority of hoods and rear decklids I've investigated have washers used as shims. I wasn't aware that there was a specific non-washer factory shim part - but then again my cars are not concours original class winners!
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Thank you!
Thanks for this information! I just bought an 86 911 and noticed the decklid was rubbing against the body. Even after adjusting it didn't fix the issue until I came across this thread. Now I have two small washers on the rear bolts between the lid and the supporting brace and everything lines up correctly.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
I couldn't find those shims in the PET the other day, so I ended up using zinc coated square washers out of McMaster-Carr.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
1980SCMan
I cut washers into a U shape (Well - an O with a chunk missing) so they can slide in. That makes the fitting process easier than pulling a bolt all the way out.
Alan,
Great idea ! Scott
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
