-   -   Looking for Tips for O2 Sensor Removal (http://forums.pelicanparts.com/porsche-911-technical-forum/834141-looking-tips-o2-sensor-removal.html)
wrxnofx 10-15-2014 07:45 AM
I'm trying to replace the O2 sensor on my '87. :mad:
Half hour job my butt.
I was able to grind off all the bolts that hold the heat shield on, so it's just me against this sensor. With a 22 mm open end wrench, this thing doesn't budge. I can actually feel the wrench flexing.
I sprayed some PB blaster on there last night and will probably give it a few more shots again before trying again.
I don't have access to a torch. What other tips can anyone offer me?
Should I drive the car first to heat up the manifold?
Would I be better off using an O2 sensor socket like this one from HF along with a breaker bar? Or will that just flex the socket and end up stripping the points on the sensor?
I don't want to cut the wires if I don't have to, because I'm afraid even if I do I still won't be able to get the darn thing off, and then I can't drive the car. Drilling seems out of the question...
Any advice you can offer me is appreciated.
Matt
scarceller 10-15-2014 08:04 AM
Cut the wire and get a closed wrench or full socket on it with a breaker bar. You will need to replace the sensor but the best is to cut the wire.
PB Blast it and also try removing it when hot after letting motor warm up. You may even need to heat the bung that the sensor is threaded into with a torch.
The sockets for removing these sensors don't work well if the sensor is that tight. I have these tools and they simply will slip at more than 100 foot lbs.
psalt 10-15-2014 08:10 AM
Matt,
Sorry, but my experience is that if it is stuck, heat is the only answer. A minute and a half with a $15 propane torch will usually do it. You need one.
Targa Me 10-15-2014 08:49 AM
Originally Posted by psalt (Post 8306931)
matt,
sorry, but my experience is that if it is stuck, heat is the only answer. A minute and a half with a $15 propane torch will usually do it. You need one.
+1
bpu699 10-15-2014 09:03 AM
Yep. Heat, and an impact hammer, is what it took. And the threads were pretty buggered up...
Bo
KTL 10-15-2014 09:10 AM
You don't need to cut the wire. Unplug the wire inside the engine bay, push the rubber grommet out of the engine sheetmetal. Then you can slip the pigtail connector and grommet thru the closed end wrench. Shock is your friend here because you need to break the rusty bond. Hammer on the free end of your wrench with a heavy hammer.
wrxnofx 10-17-2014 07:15 AM
I had this same idea, Kevin. I think this weekend I'll have some time to revisit. PB Blaster + shock hopefully = :). If not, then I'll have to get a torch and try some heat, too.
Thanks for the ideas. I'll report back what happens.
The cap'n 10-17-2014 07:31 AM
BTW, your car will run pretty well with the O2 sensor disconnected, so don't let that get in the way of your efforts to remove the sensor.
The Cap'n
yelcab1 10-17-2014 07:33 AM
Are you trying to save the sensor? If not, cut the wires or get a special O2 socket.
wrxnofx 10-19-2014 12:32 PM
Success!!!!
Got it out. However, the threads in the manifold bung are pretty knackered up. What thread size is the sensor, anyone know? Gonna need to chase them or retap them...
The cap'n 10-19-2014 02:29 PM
M18x1.5. Old Fords used this thread for spark plugs, so thread chasers are pretty available. Here's a tool number from Google: Lisle LIS12230 Oxygen Sensor Thread Chaser. I'm guessing you'll find it at your FLAPS, but it might be WAY cheaper online.
The Cap'n
Bob Kontak 10-19-2014 02:54 PM
+1 - You will find it at O'Riellys or NAPA. Auto zone / Advance Auto, doubt it.
FWIW, Called Advance Auto for an 8MM triple square bit. Response was, "Huh"?
NAPA had it in stock.
wrxnofx 10-19-2014 03:36 PM
Thanks, guys! Found it at O'Reilly and got the job done.
Tip for anyone in the future who uses one of these things: don't use the 3/8" drive. Rather, use a 3/4" socket. It distributes the load better. I broke mine using the 3/8" drive.
So, what did I learn/how did I do it?
1. I brought the car up to operating temperature first.
2. I used a pick and small screwdriver and scraped under the actual sensor where the crush washer meets the manifold to remove as much rust as possible. Then I took a small screwdriver, put it under the sensor against the crush washer, and smacked it a few dozen times with a hammer to hopefully loosen the rust.
3. I then sprayed some PB Blaster, let it sit for about 20 mins.
4. I didn't cut the wire. Per Kevin's suggestion above, I disconnected the sensor, pushed the grommet out of the sheetmetal, and fed the dongle and grommet through a 22mm box end wrench. Then I reefed the piss out of it.
5. I bought an M18 x 1.5 thread chaser from O'Reilly Auto parts and, using some cutting oil, chased the threads, which were pretty beat up. If/when I do it again, I'll use a 3/4" socket with the chaser, rather than a 3/8" drive.
Bob Kontak 10-19-2014 04:49 PM
Sweet.
For the future, in these types of situations, I like to use Mapp gas and a standard propane torch.
If I have a "special" POS, MF'ing, PITA fastener I have the Bernz-o-matic Oxy/Mapp(Propane) torch setup. It will turn everything a nice dull red but it will not pull off a cherry glowing red like oxy/acetylene.
Bummer is the red oxy tanks run out after about two jobs.
BERNZOMATIC Welding and Brazing Torch Kit - G4720204 at Zoro
KTL 10-20-2014 07:42 AM
Well said! :D
PabloX 10-20-2014 08:11 AM
Some general techniques for dealing with rusted fasteners in an exhaust system:
- PB Blaster or other penetrating oil (not WD40) multiple times over a week leading up to the job.
- If fastener is in good shape (points not rotted away) and it won't come out just use a MAPP torch straight off (assuming you won't destroy anything nearby that you need).
- Use a *good* 6 pointed socket or box wrench. Snapon, for example, has sides that are slightly convex so grab the flats on a bolt well. For an O2 sensor, get the special socket.
The heat is key IMO. For something like an old O2 sensor that I didn't care about, if I knew it were frozen, I'd be temped to cut the top off so a socket would fit over it, heat it so it's glowing and then odds are it'll come out. Put anti seize on the new one.
bcheney 10-20-2014 06:35 PM
O2
Since we are in this topic...how does one know that an O2 sensor is bad? What symptoms will be evident? I have an 89 Targa.
PabloX 10-20-2014 06:41 PM
Good question. In general terms, if you're getting bad gas mileage and/or the engine is low on power, simply replacing the sensor isn't a bad idea. Also, I had the bouncing idle problem and replacing the O2 sensor on mine helped but didn't cure it.
Here's a good test otherwise.
https://www.youtube.com/watch?v=QM2jO0_Cah0
Roger Shultz 10-20-2014 06:45 PM
How do you know the O2 sensor is bad? In my case on my 87 Targa 3.2 I had a nasty case of the "herky jerkies" when it was cold in lower gears. As it warmed it became less jerky at low RPM. I suffered with it for a couple years, pulled the connecting wire, it got way better. I couldn't get the O2 sensor out (but have a nice 22mm open end wrench in the tool box now!) so I took it to my servicing place who managed to get it out and installed the new O2 sensor. It's been fine ever since.
gliding_serpent 10-20-2014 06:56 PM
Originally Posted by wrxnofx (Post 8306885)
Half hour job[/URL] my butt.
this made me laugh. I can't tell you how many "easy" "30 minute jobs" took me forever because of one damn stuck bolt or something. Cars would be easy to work on if not for unexpected hangups. Instead I end up swearing and occasionally throwing things. I find nothing beats shear rage for dislodging something.
My DIY rule is if someone says it will take X amount of time... they are lying so triple it. Double the DIY cost. It is like asking a woman how many men she slept with in her life; she will lie and minimize the number. Same for men reporting diy times/cost on an internet forum.
merlinfe 10-20-2014 08:25 PM
For anyone else looking for an alternative removal of an O2 sensor (only if you're not going to reuse it): Destroy it down to just the nut and use a 6 point socket with a large breaker bar. 1/2" worked the best for me. Then buy a thread chaser and be done with it.
OP sorry you had issues brother. Little things like this suck the life from you sometimes. I just replaced my cat with a Euro pre-silencer. What should have been a couple hour job turned into a week long life struggle involving multiple power tools and various cutting/drilling items. I won, but the cost was high on both sides. 31 year old West German steel bolts became "one" with the exhausts flanges. Not fun.
- Steve
Kraftwerk 10-20-2014 08:31 PM
"M18x1.5. Old Fords used this thread for spark plugs, so thread chasers are pretty available. Here's a tool number from Google: Lisle LIS12230 Oxygen Sensor Thread Chaser. I'm guessing you'll find it at your FLAPS, but it might be WAY cheaper online.
The Cap'n"
I love info like that...
wrxnofx 10-20-2014 09:14 PM
- Steve
This is good advice. I was originally trying to save the sensor because, like someone else asked above, I didn't actually know if my sensor was bad. However, like the threads in the bung, the ones on the sensor are totally trashed so I couldn't reuse it anyway. In the future I'll probably hacksaw off the top of it so I can just stick a regular socket on it.
I'll also probably get a torch, too. :)
