-   -   Smuggler's box question (http://forums.pelicanparts.com/porsche-911-technical-forum/834214-smugglers-box-question.html)
vancouver86/911 10-15-2014 01:37 PM
What is the ribbed plastic tube for and where does that big round hole in the bottom of the smuggler's box go?
http://forums.pelicanparts.com/uploa...1413408937.jpg
wwest 10-15-2014 01:52 PM
The ribbed tube is the drain for any water that enters via the fresh air inlet vent just at the rear of the hood. The opening is the A/C evaporator inflow duct from the driver's footwell area.
LM3929 10-15-2014 08:26 PM
We need a place to have a real tech night for all of us in this area that isn't set up by the Vancouver ( sorry) Porsche club where us novices can ask people those questions we would rather ask between friends
Lorne M.
afterburn 549 10-16-2014 07:20 AM
talk to gaunter
tcar 10-16-2014 08:16 AM
...Passenger footwell area, not Drivers...
Hawkeye's-911T 10-16-2014 09:52 AM
By:LM3929
We need a place to have a real tech night for all of us in this area that isn't set up by the Vancouver ( sorry) Porsche club where us novices can ask people those questions we would rather ask between friends.
That would be good!
Cheers
JB
Hey vancouver86/911 - my apologies for what looks to be a thread hi-jack of sorts.
carrera30 10-17-2014 09:50 AM
Where it at
U'r/We're from the wrong side of the pond!!
304065 10-17-2014 10:28 AM
The circular pipe does not connect to the drivers, or passenger's footwell.
That is a vestige of the Webasto heater which connects there and pulls air in from the center tunnel. Air enters through a grille that covers the shift coupler, flows up the tunnel and goes into the webasto, where it flows across a stainless steel heat exchanger, gets very hot and then flows out to the defroster and heat tubes.
Ayles 10-17-2014 11:04 AM
I plugged mine with a cap from a plumbing supply store. Painted it black and dropped it in. Fit perfectly. Let me know if you want pic of what I did.
vancouver86/911 10-17-2014 12:23 PM
This is what my smuggler's box looks like in my non a/c 86 Carrera. Is it likely that this hole was covered up by someone? That holes looks like it lines up perfectly with the opening at the bottom of the evaporator blower assembly I have.
http://forums.pelicanparts.com/uploa...1413577141.jpg
pete3799 10-17-2014 12:42 PM
If it's a non A/C car and that's the only hole in the floor, than the hose in your picture (fresh air drain) should fit down through it.
vancouver86/911 10-17-2014 12:47 PM
The hole in the floor of the smuggler's box I was referring to is the huge one that is evident in the top picture of someone's car but not in the bottom picture of my smuggler's box.
david c. 10-17-2014 01:09 PM
+1 for an appropriate, accurate use of the word "vestige." Refreshing. (Pun intended.)
wwest 10-17-2014 03:55 PM
The BIG round hole next to the (US, non-ROW) steering shaft is the A/C evaporator inflow duct from the driver's footwell area.
wwest 10-17-2014 03:59 PM
Factory shipped non-A/C equipped, holes/ducts not there.
vancouver86/911 10-17-2014 06:12 PM
Does this hole need to be cut out to retro fit the stock a/c system?
