Random smoke on startup. Should I be concerned? (with video)
Sometimes I'll start the car after not being driven for a while and there will be no smoke. Other times (like in the video) I'll drive it for a while, shut it off for ten minutes, fire it up again and it will smoke on startup. The time can range from a few seconds to up to a minute.
Oil level is about half way on the meter and on the dipstick. Is this normal? PPI showed good compression and leakdown numbers.
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Old 10-15-2013, 02:02 PM
emac's Avatar
Long answer, normal
Ernie 81sc
Old 10-15-2013, 02:13 PM
My car does exactly the same. Its pretty normal.
1988 911 Carrera 3.2 Coupe
Grand Prix White/Black Interior
Old 10-15-2013, 02:17 PM
that looks pretty normal to me -- You might want to try letting the car idle until, if warm, the oil level gauge comes back up to the half way point -- smoking on startup is frequently caused by oil in the sump seeping by the rings into the combustion chamber -- letting the car idle allows it to pump the oil out of the sump . ..
Old 10-15-2013, 02:20 PM
Nothing to worry.......
Rocky,
Many car owners including myself would love to have that amount of 'smoke' during a cold start. If the video was indeed a cold start that's a pretty darn good engine!!!!! That smoke you see is just the effect of condensation in the muffler and most CIS/Motronic engines I know take much longer to dissipate the 'condensation smoke' during a cold start.
Tony
Old 10-15-2013, 02:25 PM
Thanks. The engine was warm in the video. Other times I will cold start and there will be no smoke at all. Other times it will smoke for a good minute or so. It just seems completely random which is why I was confused.
The oil gauge seems to stay around 1/4 even if I warm it up idling. Only when I start to drive for a bit will it pop up to 1/2 or white.
Old 10-15-2013, 02:35 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As per the other posting, water burning off and would bet that you are dripping water from the muffler during the smoking.
Btw don't trust the oil gauge but that is another subject onto itself...
Who Will Live... Will See
Old 10-15-2013, 02:44 PM
Still here
pmax's Avatar
This vid brings a smile to my face.
Porsche Targa with 911SC Engine White Smoke - YouTube
The soft window SC rocks !
Old 10-17-2014, 06:00 PM
Band.
It's fine!
Everytime you park the car, sit there and idle for 30 seconds or so and let the OEL gauge go up towards the top (wherever it usually sits warm.) More oil in the tank = less in the engine, and less to seep into the combustion chamber.
Or so I heard.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-17-2014, 06:26 PM
TheSt|G's Avatar
It's fine!
Or so I heard.
Correct, and good for cycling the oil past any hot spots. Read the owner's manual, it specially says to let the car idle for minute after a drive.
Old 10-17-2014, 06:53 PM
db_cooper's Avatar
very normal..911s "wet sump" when parked,, it is a dry sump engine by design.
Old 10-17-2014, 07:00 PM
emac's Avatar
Rocket-- before you shut her down let her idle for a minute , I have found this helps but as I stated earlier -- normal
Ernie
Ernie 81 SC
Old 10-17-2014, 09:42 PM
Band.
I've also heard that before you park, you should let it idle for a minute.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 10-18-2014, 06:58 AM
