-   -   83 sc backfires won't run help please (http://forums.pelicanparts.com/porsche-911-technical-forum/834525-83-sc-backfires-wont-run-help-please.html)
boyt911sc 04-25-2015 07:06 PM
Using the pressure gauge kit.........
Michael,
You don't need to remove the metal/rubber fuel line between the WUR and FD to check the fuel pressure. You could either install the pressure gauge kit at the FD or at the WUR. But it is more convenient to use the WUR side. Why? There is more room to work at this area plus the fitting (12-mm x 1.5) at the WUR is the same as the one on your gauge. At the FD side, you need 8-mm x 1.0 fittings. My suggestion to you at this point, is try the WUR side because you got the needed fittings in your set. Keep us posted.
Tony
roadster49 04-26-2015 07:39 AM
Hi Tony and Bob,
I hope I did this correctly: the temperature in Troy, MI was 39 F which is 4.4 C
Hooked up pressure meter to the WUR and to the rubber line disconnected per Tony's description.
System pressure, with valve closed was 6.6 bar
control pressure with WUR plugged in and valve open was 6.6 bar at 8:47,
At 8:57 it was 5.9 bar and stayed at that number till 9:04 when I went to open the return fuel line.
With the return fuel line open the pressure was 5.0 bar
Next step please?
timmy2 04-26-2015 09:00 AM
Post a picture of your hook up. Here is how to do it:
Remove line from fuel distributor to WUR at the WUR only.
Connect removed line from FD to gauge side of shut off valve. (No valve between removed line from FD and gauge)
Connect line with shut off valve after the T directly to the WUR fitting.
With valve closed pump running is system pressure.
With valve open pump running, WUR power disconnected is cold system pressure.
Pump running, valve open, electrical connected to WUR for 5 minutes is warm pressure.
Bob Kontak 04-26-2015 10:12 AM
Originally Posted by roadster49 (Post 8595384)
Next step please?
Your pump is designed to deliver 5.2 bar. I can't deliver 6.6. Replaced with a different type?
(That said, I do not think the Accumulator is a pressure regulator - it's just a fuel flow "shock absorber" - I may be wrong)
You removed the return line to the tank (downstream of WUR?) and control PSI stayed at 5 bar with test valve open from dist to WUR?? Clog in WUR? This is getting into the area where you need to be real nice to Tony.:)
This is the basic hook up. Is yours like this? Let's make sure you are hooked up correctly like Timmy says.
http://forums.pelicanparts.com/uploa...1430068200.jpg
tirwin 04-26-2015 10:58 AM
My understanding of the fuel accumulator is that it does two things. It acts as a sort of check valve to help maintain residual pressure after shutdown and it acts as a smoothing function for fuel delivery rate. The fuel pump has some small amount of variation in the rate of fuel delivery at a certain pressure. The FA smooths out the variation to make the fuel pressure more consistent. In a telecom network we would call this a shaper, buffer or a queue.
Bob Kontak 04-26-2015 11:07 AM
Thanks. Well, it sure does seem the check valve is working fine.
Your thoughts on the 6.6 bar of system pressure?
roadster49 04-26-2015 11:11 AM
Per the above here is my test set up
http://forums.pelicanparts.com/uploa...1430071806.jpg
roadster49 04-26-2015 11:14 AM
Here is the systems pressure
http://forums.pelicanparts.com/uploa...1430072058.jpg
roadster49 04-26-2015 11:20 AM
Here is the pressure with fuel return open:
http://forums.pelicanparts.com/uploa...1430072371.jpg
http://forums.pelicanparts.com/uploa...1430072415.jpg
I am going to retest as the numbers seem out of boiunds.
Bob Kontak 04-26-2015 11:27 AM
Looks set up correctly.
If it is, you have a blockage between the inlet to the WUR and the return line connection.
Blow on the return line to the tank to make sure that will take flow (eliminate variable).
Pull the Porsche connector off the top of the WUR. The thing your gauge is connected to. There is a little screen in hole. Check if clogged.
Bob Kontak 04-26-2015 11:33 AM
Here is a simple test. Valve open and you are reading 5 bar. Crack the line (on the WUR) just to the rear of the big WUR connection. Your pressure should drop as gas leaks out.
If it does not drop, the blockage is isolated to the WUR.
Bob Kontak 04-26-2015 11:44 AM
Michael,
Can't tell from your first pic in post #49 what is disconnected.
Return line is the bottom of the two big green lines way in the back (well, front) of the engine compartment.
This is where you disconnected and got 5.0 bar?
http://forums.pelicanparts.com/uploa...1430073843.jpg
roadster49 04-26-2015 12:06 PM
I retested it here are pictures
set up
http://forums.pelicanparts.com/uploa...1430075089.jpg
http://forums.pelicanparts.com/uploa...1430075102.jpg
valve closed
http://forums.pelicanparts.com/uploa...1430075115.jpg
valve open
initial
http://forums.pelicanparts.com/uploa...1430075131.jpg
after 10 with WUR plugged in
http://forums.pelicanparts.com/uploa...1430075147.jpg
roadster49 04-26-2015 12:12 PM
Hi Bob,
It is the hardest connection to get to, way in the back with a 13MM on hose to green pipe in firewall and 17MM the hose going to the engine.
Yes this is where I got 5.0 bar with the hose disconnected.
Need to shut down for the day. I can check the screen and crack a connection next week.
Thanks,
Michael
roadster49 04-26-2015 12:25 PM
Well i am heading to the airport so will pick up from here next week.
Thanks all.
Michael
Bob Kontak 04-26-2015 12:29 PM
Good work.
There are two suspect places the flow can plug.
WUR and then at the fuel distributor aside from the line itself.
Check this diagram out. Pretty easy to follow.
911 CIS Primer - CIS Lambda
boyt911sc 04-26-2015 03:37 PM
Visual inspection......
Originally Posted by Bob Kontak (Post 8595719)
Good work.
Michael,
I can't see well from your pictures if it was the return line or not. If the return line was opened and fuel pressures remained high, then the problem is upstream. Restriction is occurring some where between the the return line open section and the fuel distributor. There is a strong possibility that FD is causing the very high system fuel pressure.
If I were in your shoes, I would do this test to determine whether the high system pressure is caused by the primary valve or a restricted fuel line right after the FD. Leave the return line open but place it in a container. Loosen the primary valve and remove all the shims or washers. Tighten the primary valve and repeat the pressure test.
a). If the system fuel pressure remains at 6.6 bar after removing the shims or washers, the problem is not the primary valve. It could be a clogged FD or the return line after the FD.
b). If system pressure drops down significantly, you found the culprit.
Tony
Bob Kontak 04-26-2015 04:12 PM
Hi Tony,
Same question I asked in post 52 and then he responded in post 54. He sees to have it correct.
I am going to call you tomorrow. I want to talk about the fuel distributor aspects of the probable clog.
What time does your wife wake you up from your beauty sleep?
boyt911sc 04-26-2015 05:17 PM
Give me a call ASAP........
Originally Posted by Bob Kontak (Post 8595982)
Hi Tony,
Bob,
I am on my way home from baby sitting and should be back home by 9:00 PM. I will wait for your call between 9:00 and midnight. Love to hear your voice again and reprimand you for being a naughty boy. Maybe you could update me about the reverse gas discussion......... you still owe me one over-cooked hamburger.
Tony
Bob Kontak 04-26-2015 05:58 PM
Originally Posted by boyt911sc (Post 8596118)
Bob,
Tony
This old coot is going to bed now.
Tomorrow in the afternoon.
Farrell 04-26-2015 08:33 PM
I had very small backfires on my car. I can't see where my airbox is broken but that's what my shop told me is wrong. From what everyone says here it sounds like a shotgun goes off and I should here a loud pop from my airbox too I would assume. Thing is, none of that happened.
My car runs just has no power when I try and accelerate. Is it likely the same culprit?
boyt911sc 04-27-2015 05:44 AM
Want to get your attention.........
Tim,
First of all, I am not picking on your post but just wanted to get your attention. Since you are collecting pertinent information for your "Dummies thread......" The above post needs some further review. Not only it is misleading, you were successfully able to convince Mr. BK to agree. It did not describe what it really does.
These are my comments for the above post:
1). The fuel accumulator is not a check valve in any way or manner. Dissect an old FA and you will see what's it does.
2). It has not described what a FA does and the information is partially true and partially false. And misleading to a point that BK accepted or agreed to them as a fact.
3). Find a Bosch technical bulletin about "Mechanical Gasoline Fuel-Injection System..........K-Ketronic" (ISBN:0-8376-0468-0). Everything you need to know about CIS are well detailed, demonstrated, and explained. Highly recommended reading material.
You are doing a very good job in educating fellow CIS enthusiasts by collecting pertinent and well documented posts in your thread. We all make mistakes including myself but if we don't try to correct these mistakes, we would be contributing to the spread of misinformations. This is a technical forum and we could discuss, disagree, or contradict each other but end of the day we all are still friends.
Tony
Bob Kontak 04-27-2015 07:56 AM
Hey Tim,
I am feeling a lot of friendly "team" love as a result of that ass kicking you just received from "Chuckles" Donato.
Chuckles,
If you would have asked me two days ago, before I posted and received info from Tim, I would have said it's a shock absorber and check valve.
I just was not sure it was or was not a regulator.
I does have a one-way flow function, correct?
roadster49 04-27-2015 09:02 AM
Hi Tony & Bob,
I will return to Michigan on Friday and will do the procedure recommneded. As a benefit I am getting quick at setting up the pressure testing and learning a systematic analysis.
thanks,
Michael
boyt911sc 04-27-2015 09:18 AM
Fuel Accumulator.......
Originally Posted by Bob Kontak (Post 8596821)
Hey Tim,
Chuckles,
Bob,
The technical bulletin has the literature to describe it and comes with a very understandable illustration. It is not a pressure regulator nor a check valve. Inside the FA is spring loaded diaphragm that absorbs or dampens the sudden flow of fuel from the fuel pump. In short, it has an expandable volume. A shock absorber is an acceptable description.
Imagine taking a deep long breathe and inhale some air and hold it for a few seconds. Your chest cavity expands and stomach contracts (ignore the stomach it might not be applicable to you.....just kidding). Hold your breathe as long as you could comfortably and slowly breath out. This is what the FA does with the residual fuel pressure. When you stopped the FP from delivering fuel the control pressure would register slightly higher the instant the FP stops. Why? The spring loaded diaphragm inside the FA reacts/contracts against the FP delivery pressure. Try to observe the pressure deflection next time you measure the control fuel pressures. If you do not observe this small pressure deflection, either the FA is bad or the fuel is leaking back to the tank.
Lastly, what do you mean one-way flow function? The correct installation of the FA is inlet at the side port and outlet at the center. However, if you installed it the other way around (inlet at the center) it still would work. I had inadvertently installed the FA (center port as inlet) in my CIS bench tester until I noticed it. And it was months and lots of testing done with this set-up and found no adverse effect on my data.
BTW, how's the restoration and repair of your car now? Done with the repair?
Tony
tirwin 04-27-2015 07:06 PM
Tony,
I have been traveling on business and working on my car when I haven't been at work so I didn't see your response.
I want to clarify my previous statement - perhaps I was unclear. As I understand the general function of a fuel accumulator (not necessarily specific to a Porsche) is to provide one-way delivery of fuel (i.e., keep the unused fuel in the fuel lines from returning to the tank) and maintain pressurization after shut off. A symptom of a failed FA would be rapid loss of residual pressure, no?
In some countries, they call the FA a Fuel Damper. Maybe it is a terminology difference but I think this actually might be a more descriptive term for what it does. Sometimes our choice of words get in the way of communicating the intended meaning.
If there is a difference in the way Porsche used the FA in the CIS system, then that's fine and duly noted. But I don't think my explanation is entirely wrong either. We could talk in more detail about what happens and why but I'm not sure it helps the OP.
My intention was not to create a diversion. Apologies if that was the case. Carry on...
Bob Kontak 04-28-2015 11:46 AM
Tim,
Tony is correct. All these years I had the same faulty image of it's function. When descriptions say it "holds/maintains residual pressure", I think check valve.
Even if "sort of" a check valve, it should not allow fuel to flow backwards.
It's neither.
Fuel can flow through the accumulator unrestricted. It's an open tube with an in and an out on the bottom. That's it. However, there is a big spring and diaphragm that forces down upon the fuel, essentially creating residual pressure.
http://forums.pelicanparts.com/uploa...1430246731.jpg
See pdf page 7:
http://www.usefulstuff.pwp.blueyonder.co.uk/myfiles/KJet.pdf
Cool beans. Thanks, Tony.
roadster49 04-30-2015 03:37 PM
As Tony suggested, I removed all six shims from the primary valve
http://forums.pelicanparts.com/uploa...1430433083.jpg
http://forums.pelicanparts.com/uploa...1430433101.jpg
With the shims out I checked pressure with the return line connected
http://forums.pelicanparts.com/uploa...1430433184.jpg
So 5.5 bar is better but still above 5.2, and I have no shims in the FD
Retested with the return line disconnected
http://forums.pelicanparts.com/uploa...1430433223.jpg
Recomendations please
boyt911sc 04-30-2015 04:35 PM
What I suspected earlier........
Michael,
The reason I requested you to remove the primary valve's shims was to see if the high system reading was caused by a flow restriction or by the primary valve itself. That's a new primary valve the previous owner installed including all the shims that came with the repair kit!!!!!! The system pressure without any shims at all is still out of spec. at 78 psi. Like to drop it 72 psi. (+/-1).
Let's do a quick test. Do you have another crush washer for the primary valve available to use for the test? If you install a second crash washer, check the resultant system pressure for me. Keep us posted.
Tony
boyt911sc 04-30-2015 04:48 PM
Additional picture needed.......
Michael,
Could you post a picture of the primary valve's piston/plunger? I like to see the top of the plunger. Thanks.
Tony
roadster49 04-30-2015 06:12 PM
I put an aluminum washer on the valve:
http://forums.pelicanparts.com/uploa...1430442515.jpg
Pressure is down to 64 PSI
http://forums.pelicanparts.com/uploa...1430442619.jpg
Next steps?
Michael
roadster49 04-30-2015 06:24 PM
Here are the requested pictures
http://forums.pelicanparts.com/uploa...1430443413.jpg
http://forums.pelicanparts.com/uploa...1430443428.jpg
http://forums.pelicanparts.com/uploa...1430443440.jpg
http://forums.pelicanparts.com/uploa...1430443451.jpg
boyt911sc 04-30-2015 08:29 PM
Missing primary valve's piston.......
Michael,
Where is the primary valve's piston/plunger? Use a magnet to pull it out from the FD's cavity in case you left it inside. I like to see how it looks and I am beginning to connect the dots showing the root cause of your very high system fuel pressure.
Remember what I told you before you went to the hardware store to look for a washer? I said if the system pressure would drop to the 60's (psi.) with additional washer, the problem is not the return line by the PV's setting.
Could you check also the Fuel distributor Bosch ID number on it? Thanks.
Tony
roadster49 05-01-2015 06:58 AM
Here is FD Number ending in 077
http://forums.pelicanparts.com/uploa...1430488076.jpg
Here are pictures of plunger
http://forums.pelicanparts.com/uploa...1430488120.jpg
http://forums.pelicanparts.com/uploa...1430488166.jpg
http://forums.pelicanparts.com/uploa...1430488625.jpg
Please let me know what else to test.
Michael
roadster49 05-01-2015 07:11 AM
better picture of plungerhttp://forums.pelicanparts.com/uploa...1430489473.jpg
http://forums.pelicanparts.com/uploa...1430489506.jpg
boyt911sc 05-01-2015 07:41 AM
FD primary valve.......
Originally Posted by roadster49 (Post 8603418)
Michael,
Attached below are pictures of the FD-031 and FD-077 primary valves. I've suspected something was not right with your FD-077 primary valve configuration or set-up. Take a good look at the pictures and compare. Did you see the difference?
http://forums.pelicanparts.com/uploads19/DSCN39621319150874.jpg
http://forums.pelicanparts.com/uploads19/DSCN39641319150894.jpg
I have not investigated or tested if the primary valves for FD-031 and FD-077 are interchangeable. They could well be and the springs for these are not exactly identical.
Connect all the fuel lines and calibrate the system fuel pressure using double sealing rings and the appropriate shims. Measure the different shims' thickness and install one or two shims and check until you get the desired system fuel pressure. You are doing a good job. Keep us posted.
Tony
roadster49 05-01-2015 07:54 AM
Hi Tony - mine looks like the 78???
How would the valve body machining accommodate the difference, which looks significant?
I will build it out as you say and let you know.
Tony, thanks for all your help, your training as a scientist, engineer, and forensic investigator are exemplary.
Michael
roadster49 05-01-2015 09:27 AM
I kept the two outside washers on the valve and added shims in the following sequence:
1
http://forums.pelicanparts.com/uploa...1430497319.jpg
2
http://forums.pelicanparts.com/uploa...1430497343.jpg
3
http://forums.pelicanparts.com/uploa...1430497362.jpg
Looks like # 2; unless I swap out the copper washer for just the aluminum one to get to the 70 PSI range.
So do I try to start it now that the pressure is in line?
Do I need to do anything with the adjustment key on top of sensor?
I have had this jalopy since 2011 and it has never run well, so I am anxious to fire it up, but can wait until all testing is done as I want to avoid issues later
Michael
roadster49 05-01-2015 01:21 PM
tested control pressure. it is 72F or 22 C
here are test results (valve open and Wire plugged in) note I am only posting the first and last as the PSI did not change:
http://forums.pelicanparts.com/uploa...1430511608.jpg
http://forums.pelicanparts.com/uploa...1430511640.jpg
So not sure what happened the WUR did work before.
roadster49 05-01-2015 01:41 PM
So I tested the resistance across the WUR and it is now 9.4 ohms. Previously it was 26.6 ohms. Not sure what caused the deterioration, but thats the current value and probably why the pressure does not drop.
Suggestions?
