Leaking pop off valve
Anyone have any suggestions for fixing this?
The seal around the valve is gone.
1982 SC |
You should remove the valve, clean up the mating surfaces, and re-glue using a two-part epoxy adhesive. It's hard to tell from your photo, but it looks like the ridges in the air box have already been ground down so the valve has a flat seating surface.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Can I do this without pulling the air box out?
1982 SC |
