-   -   911 timing problem (http://forums.pelicanparts.com/porsche-911-technical-forum/834691-911-timing-problem.html)
carrerarsr65 10-19-2014 11:03 AM
911 timing problem
timing seems to be 180degrees out z1 at bottom part of wheel
Trackrash 10-19-2014 12:25 PM
Ooookaaaayyyy. Had the distributor out?
carrerarsr65 10-19-2014 10:48 PM
k
no dizzy initial timimg afterrebuildhttp://forums.pelicanparts.com/uploa...1413784081.jpg
Flat6pac 10-20-2014 02:56 AM
You bolted the crank fire 90 degrees off. Through 3.2 the pin on the crank is at 9 o'clock for TDC
On 3.6 the TDC pin is at 3 oclock
Bruce
