car stalls when oil cap is removed.
I got a tank full of non-ethanol gas (rare in Colorado!) and now the car runs rough. When I remove the OIL filler cap - it stalls!! Any suggestions - too hi/lo octane? Add fuel drier/power booster additive? Just run it and refill as soon as possible?
Thanks.
1982 911SC Wine Red Metallic OMG I love this car! Last edited by Algernon; 10-05-2014 at 04:34 PM.. |
That's a good sign (no vacuum leaks). Your missing the restrictor in the return line to tank filler neck.
Todd
'81 SC |
Cis.......
Todd, Hope you are correct. But a properly set CIS should not stall or stop running after removing the oil filler cap. It would drop the idle speed down approximately between 150 to 200 rpm (which is a good sign) or stop running (bad news). In this case, I would suggest to inspect the breather hoses or test for vacuum leaks in the system. Tony Last edited by boyt911sc; 10-05-2014 at 05:56 PM.. |
My bad, responded too quickly. Yes, literally stalling is not good.
Todd
'81 SC |
Reiver
It could also be you are running too rich...so when you remove the cap and it lowers your rpm it cuts out.
What is your normal rpm that you set for idle?
De Oppresso Liber Strength and Honor 5th Legion |
It normally runs around 800 rpm when warm. I don't think dirty gas, as it runs fine when driven above idle. I'm guessing the problem is the gas, either too high(?) or too low octane. If idle is suddenly too rich, does this imply wrong octane value. Gut feeling is its too low, so maybe I should add some octane booster to the tank until I have used enough to refill tank with 'good stuff'? Am I on the right track here?
1982 911SC Wine Red Metallic OMG I love this car! |
It is the restrictor in the oil line I have seen lots of SC's do that.
It is a cheap easy fix. Our host sells them.
gone 82 928 Comp pkg 83 911 SC RS 69 911 T lightweight canyon carver outlaw soon Lotsa Ducati's 99 Triumph 995i track bike www.porscheresto.com |
Are you removing the cap right when you start the engine or after its warm. My SC drops idle when the cap is removed but the oil needs to be flowing and a bit warm. I once made the mistake of pulling the cap off right after I started the car cold, the car stalled out but that is the only time it ever did that. I now never remove the oil cap with the engine running until the car is warm. You may be running oil that is a bit to heavy or as mentioned it may also be your oil line restrictor.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
I have the same problem after removing/cleaning my oil tank on 88 911. All hoses/vacuum lines are installed correctly. Not sure if the recirculating air valve has anything to do with it; can someone advise where the 'restrictor' in the oil line is located and does this apply to non-SC motors also?? Many thanks for the help.
Fleabit peanut monkey
#1 - who the hell knows it is there? #2 - why would it fail? #3 - Who would remove it? Refer to boyt911SC's post.
1981 911SC Targa |
