-   -   Rear wheel hight/alignment question (http://forums.pelicanparts.com/porsche-911-technical-forum/834797-rear-wheel-hight-alignment-question.html)
car-nut 10-20-2014 05:01 AM
Dear experts:
I have the following short question in regard to red wheel alignment/height of 82 Porsche 911 SC. I would appreciate receiving your answers to my questions:
1. How much of change in height can one achieve with the rear wheel height adjustment bolt, without removing the rear wheel spindle off?
2. According to my measurement, I would need a 36 mm thin wrench to move the height adjustment bolt; correct?
3. In order to set the camber, do I need to loosen the height adjustment bolt and ride-height securing bolts (I am pretty sure I should)? Do I need to loosen the toe bolt as well.
4. And to set the toe; is it same as in 3 above?
Thank you for your time.
The car-nut.
boyt911sc 10-20-2014 05:43 AM
If my memory serves me right.......
Originally Posted by car-nut (Post 8314388)
Dear experts:
The car-nut.
1). If you have the OEM adjustable spring plate, it as about 3/4" (less than inch) max. range in adjustment.
2). 36 mm wench.
3). No. But has to loosen the toe-in bolt.
4). Yes. The key is keeping the cam of the other bolt from moving. For example, if you are adjusting the toe-in, the camber would be slightly changed and vice versa.
Tony
car-nut 10-20-2014 01:15 PM
Short and sweet!
Many thanks.SmileWavy
