I've developed a jiggle!
Did lots of driving this weekend Unfortunately, my steering column began to jiggle today. Has this happened to anyone?
https://m.youtube.com/watch?v=W1PpvGhToP0
Old 11-09-2014, 02:26 PM
Adrenaline Junkie
Hayabusa's Avatar
Happens to the best of us.
Pelican Technical Article: 911 Steering Column Bushing Replacement
Old 11-09-2014, 02:36 PM
Haha!
Thank you Chris
Old 11-09-2014, 02:41 PM
Use the Mitch Leland bushing our host sells. It's straight forward and well made.
Old 11-09-2014, 03:09 PM
Yep its a simple bushing swap. and the perfect oportunity to swap out that wheel
Old 11-09-2014, 03:13 PM
Thanks OldSpool! I was just looking at the part.
Since I'll have the wheel off, I may go Momo.. And since I'm making a purchase, I may go ahead and get a shiny new pedal set and floor boards. And new shift bushings. And Sein Gate..
Yikes.. This bushing is getting expensive!
Old 11-09-2014, 03:20 PM
PorscheDude, I like the way you're thinking. I've been looking for an excuse to get rid of that wheel.
Old 11-09-2014, 03:26 PM
Yes to put it nicely I see much room for improvement there
Old 11-09-2014, 04:07 PM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by clinerg View Post
Haha!
Thank you Chris
No problem, George. There is an 'S' wheel I just commented on in the FS section. I'm sure he would take an offer under his 600 ask price.
Old 11-09-2014, 08:51 PM
Detached Member
Hugh R's Avatar
Its plastic, vacuum the old crap out, and lube the new one before you pound it in. Hit it straight, you only get one chance to pound it in straight. I've heard extracting a miss aligned one is a pain.
Hugh
Old 11-09-2014, 09:02 PM
Detached Member
Hugh R's Avatar
Before a sein gate try the factory shifter and rear coupler bushings for about $35 made a World of difference on my 84
Hugh
Old 11-09-2014, 09:04 PM
Adrenaline Junkie
Hayabusa's Avatar
Btw, we all have jiggles. Some just admit it more than most.
Old 11-09-2014, 09:09 PM
Parts ordered.
Hugh - I did not get the sein gate yet. I did order all the bushings though. Thanks!
Old 11-10-2014, 09:01 AM
TheSt|G's Avatar
Definitely get the Momo. Makes all work in that area much easier in addition to its more apparent benefits.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 11-10-2014, 09:03 AM
TheSt|G,
It is time to go momo for sure. I will probably need a momo hub? The sparco wheel looks to have the same bolt pattern as momo.. Maybe I don't need a hub?
Old 11-10-2014, 09:20 AM
TheSt|G's Avatar
TheSt|G,
You need the Momo hub for sure. Also a good time to consider a spacer if you want to lift the wheel further off the dash. I'm running a 2" straight spacer and the ~1" JWest eccentric spacer to pull the wheel up off the dash and tilt it down slightly. Hugely improved as I can now wrestle the wheel without extending my arms all the way.
Old 11-10-2014, 10:31 AM
