porsche boy's Avatar
1995 993 A/conditioner clutch
Hi there porscheafiles, drove my 993 and turned on a/c. Huge screech so I turned it off and repeated a few times and a/c worked. Today, I turned a/c on in the driveway and unbelievable screech as the fan belt was turning but clutch seized. Has anyone out there experienced this and how is it fixed?
1. Replace bearings in clutch. Can you do it in the car?
2. Replace compressor.....I hope not
I hope you can help me? Any thoughts.
Old 10-24-2014, 05:11 PM
wwest's Avatar
First, check to make the v-belt is properly adjusted.
Otherwise, new pump.
Old 10-25-2014, 08:45 AM
Capitalist and Patriot
911Freak's Avatar
After checking belt tension, you may need to replace the compressor/clutch. There is a part number for just the clutch, however the cost is higher then a new complete assembly. The DENSO replacement units are good.
Good opportunity to check you a/c pressures etc.
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 10-25-2014, 09:37 AM
OK thank you. Not the answer I want but "no surprise". Why cannot it be a $10.00 part. Now today working !!!! Must be on it's way out.
Old 10-25-2014, 12:59 PM
wwest's Avatar
The clutch, of itself, is not at all likely to be the problem, much more likely the compressor.
Old 10-25-2014, 06:45 PM
