Seat Re-Upholstered
I had the drivers seat done about two years ago and realized I should of done the passenger side, but It was in such good shape. I'm using Zymol right now for conditioning and it doesn't seem to soften it up as I would like. I'll finish the container then try one of the other recommended brands.
Can I use conditioner on the Dash? It seems a bit dry.
Old 10-19-2014, 06:04 PM
Did you use a kit on the drivers seat ? .. it looks real good .. who did he upholstery work ?
Old 10-19-2014, 06:26 PM
No Kit, The gentleman that did the work is out of Bell. He does mostly BMW's. He used the old pattern and reinforced the Foam where it was tearing from the driver side bolster.
He did the floor also using the old pattern.
I can get you his number, he is in California.
Old 10-19-2014, 07:03 PM
sure ...
Old 10-23-2014, 04:09 AM
