gtrp's Avatar
Oil in airbox
Hello,
New to Porsches but I imagine a thin layer is not a good thing?
My car has trouble staying alive until it's fully warmed up.
It'll idle between 100-900rpms and stall. This will happen until I start driving it to get it warmed up, then it'll idle at 900rpms and be perfectly fine until i turn off the car.
Sounds like a vacuum leak as the car has zero change when I remove the oil cap as well.
Old 10-22-2014, 03:38 PM
Hilbilly Deluxe
emcon5's Avatar
And your car is a...........
82 911SC Coupe
GTI Cup #43
Old 10-22-2014, 03:47 PM
gtrp's Avatar
Sorry it is a 1981 911SC. Lightly modded but nothing crazy.
Old 10-22-2014, 03:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
More then likely to much oil in the tank or you don't have a restrictor in the oil breather line.
For the vacuum leak, spray some starter guild around all the connections and if the RPM's goes up, you found your leak.
Who Will Live... Will See
gtrp's Avatar
I do have too much oil in it... Dropped it off at the shop to change out my fuel lines and it seems I got a free quart or two of oil in my car...
Old 10-22-2014, 04:00 PM
JJ 911SC's Avatar
Drain some out.
On your dipstick, with the car running at operating temperature on a level surface after 1 minutes of idling, you should be half way between the low mark and the hight mark.
Get into the habit of when returning from a ride, to check the level as describe above.
Do not rely on the oil level gauge.
Old 10-22-2014, 04:05 PM
gtrp's Avatar
Okay I did that after a good drive, couldn't get it to idle sitting still for 1 minute.
Old 10-22-2014, 04:19 PM
JJ 911SC's Avatar
The idlin is just to let the oil return to the tank, it does not matter if its steady at 900 RPM or hunting.
So where was the oil level at?
Old 10-22-2014, 04:38 PM
gtrp's Avatar
Max.
I only mention the idle because it's seems more troubling. It's causing my car to die at stop lights.
Old 10-22-2014, 06:56 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
Oil level
My 80 US 3.0 conversion did not have the vent baffle & a slightly low oil level was super critical. Motor will hunt when you check oil running because the tank is open to ATM. Best of luck.
Old 10-22-2014, 11:16 PM
JJ 911SC's Avatar
Max.
Take some out (about ¾ quart) and found those vacuum leaks.
Old 10-23-2014, 02:53 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Max.
Vacuum leak, now the fun starts, get busy!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-23-2014, 05:36 AM
gtrp's Avatar
Perfect, thanks!
I appreciate the help everyone. Love working on the porsche after work so this should be fun times.
Quote de gtrp
Max.
Old 10-23-2014, 06:20 AM
Restrictor? Where is that? Just curious, as I have also noticed some oil in the airbox if the oil level is just a teeny bit high... I have never seen a restrictor
Bo
Old 10-23-2014, 06:35 AM
lespaul's Avatar
Also curious about location of restrictor in oil breather line. I have a stock 78 SC.
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 10-23-2014, 07:08 AM
Designer King
Paulporsche's Avatar
Idle hunting is often a sign of a too rich mixture. It may simply be set too high or your WUR (warmup regulator) may not be functioning correctly. It's also possible someone has raised the CO% to make up for air leaks.
There is a huge number of posts on finding vac leaks, setting the mixture and troubleshooting the WUR.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-23-2014, 10:00 AM
gtrp's Avatar
Thanks Paul!
- Paul
Old 10-23-2014, 10:33 AM
JJ 911SC's Avatar
Bo
It fit in Oil Tank Breather Hose at the oil tank end.
Small piece like a reverse funnel to limit oil reflux into the crankcase.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Old 10-23-2014, 11:04 AM
scarceller's Avatar
I run my oil level just slightly below 1/2 mark, like 3/8 full. I have found that anything above 1/2 way tends to get oil into the breather hose and then into the intake on the 3.2L cars. I'm sure the SCs are in the same ballbark. Does the SC vent before the air funnel meter or after it? I assume they vent between the air funnel meter and the TB?
Bottom line is wet oil in the intake is not good as it will mix with intake air at WOT and reduce the fuels octane rating and could trigger detonation. You really want a nice dry intake track if possible.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-23-2014, 11:29 AM
scarceller's Avatar
But what direction should it be installed in? I have seen them installed in both directions. My guess is that the best way for the device to be installed is with the funnel pointing toward the tank, not the most obvious direction for air flow but I do think it's best for keeping oil from passing the funnel. Oil normally sticks to the walls of the hose and is then sucked along the wall toward the intake. If you place the funnel as I suggest it sort of stops the oil right at the funnel since the funnel is backwards to the direction of the oil travel.
Thoughts? I've never seen a answer for this?
Sal
1964 356SC (SOLD)
Old 10-23-2014, 11:35 AM
