Yikes
At the marina we blow-boaters sometimes like to have a little fun and toss a beat up and bent cotter pin on a guys deck right before a big race or vacation cruise...
Today I found this beside the rear driver's wheel on my '69 911. Does anyone recognize this ball? It's too small to be from a wheel bearing or half-shaft. Any ideas? Sure, it's probably from a bicycle hub or something else- BUT if anyone of you think it's from a 2 liter please let me know!
83 911 Production Cab #10
I had one like that in the old heat exchanger when I put the SSIs one...
Like we said in the Navy, F?c?nose
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
1980 911 SC Targa
Gall stone .... 2 liters do that once in awhile !
Joe 1980 911 SC Targa 1998 911 Carrera S. Sold 1964 356 Sold 1983 944 track car. Sold |
that looks suspiciously like a muffler bearing ;P -- see https://answers.yahoo.com/question/index?qid=20111025070854AANk1A4
Mine was from a 3.2
So, somewhere between the heat exchanger and the tail pipe, there is ball bearings in play? Probably from the catalytic converter.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 10-21-2014 at 03:58 PM.. |
Brando
A joke right?
Turbo powa! 1977 911s. it's cool |
High speed muffler bearing. Lubricate with turn signal hydraulic fluid.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Seriously, do you have a floor jack with a sloppy wheel bearing?
I'm rather surprise with your come back comments (from rather senior poster) as I'm pretty sure we had exchange on other threads so I'm not trolling. I'm no pro but in the last 5 years, I pretty well did everything to the car short of splitting the case (drop engine, change: clutch, fly wheel, brakes, back heated with SSIs, installed a PMO EFI system with Electromotive ECU system and so on). So back in 2011 when I found the bearing in the original heat exchanger, I was almost sh?ting brick but since the engine was running OK so I dismiss it but always wonder where it came from.
ok, seriously, you found this on the ground behind your rear drivers wheel... and you think it fell out of your "did everything to the car short of splitting the case (drop engine, change: clutch, fly wheel, brakes, back heated with SSIs, installed a PMO EFI system with Electromotive ECU system and so on). " and you're not dismissing it????
1984 Carrera Targa |
That looks like a common 6mm bike hub ball bearing to me (at least all my old non-sealed hubs run 6mm balls).
I love the cotter pin trick! |
Could be from a swiveling ratchet. I had mine come off with the spring.
Balled Eagle poo?
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
No, read post # 2 again.
@ Gene. There are no bearings like that in your engine.
John "Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage |
Balls
Thanks fellas. I was NOT having a conniption- Hell I'm going to trash that ball today!
Gene |
I found the source today-
Harbor Freight electric impact gun. The detent ball for the socket head is missing... |
83 Targa
It's gotta be da ball bearings...
Fletch |
OK, well hopefully that solves the problem, I was going to say it could possibly be from a worn out seat slider.
