-   -   Hood should close upon dropping or does it require (http://forums.pelicanparts.com/porsche-911-technical-forum/836505-hood-should-close-upon-dropping-does-require.html)
bcgreen 10-30-2014 06:15 PM
an additional push to close? I have to lower the hood then push down to lock it in place.
I am thinking you should be able to just drop the hood to close it.
Oh Haha 10-30-2014 06:36 PM
The extra push is normal. Most owners I know push on the Porsche crest to complete the closure.
KBOUSTANI 10-30-2014 06:37 PM
That's how I di mine ,push on the Porsche crest.
gazzerr 10-30-2014 06:43 PM
I need to push mine.
Jp-oh 10-30-2014 06:52 PM
I reach under the hood and move the latch over then lightly push the hood closed.
jmpowers 10-30-2014 06:54 PM
I push on mine but NEVER on the crest. Been told it will loosen the crest eventually...http://forums.pelicanparts.com/suppo...eys/hiding.gif
Joe Bob 10-30-2014 07:00 PM
Why would you drop your hood from a height? Do you do that with a Chevy?
Jfporco 10-30-2014 07:20 PM
Let the hood down with my hands, then gently close it at the edges.
No need to let it slam down.
Arne2 10-30-2014 07:47 PM
This. In fact, since my gas support struts are working, I doubt I could just let it fall at all.
bcgreen 10-30-2014 07:56 PM
I have seen programs on TV where a guy says people make the mistake and push on the hood and this eventually distorts the hood where you press down. I may have my cars mixed up and it may have been a Ferrari.
Glad to know that I have been doing it as everyone else and this makes one less thing I need to do.
bcgreen 10-30-2014 07:58 PM
My strut needs to be replaced and now this is making sense that you shouldn't be able to let it drop.
Mark Salvetti 10-30-2014 08:34 PM
The hood on my SC is distorted that way just above the crest. I'm sure it's from a PO closing the hood by pushing down with both hands in that area. I bet just one time was enough.
Mark
Tidybuoy 10-30-2014 09:24 PM
my hood shocks will pop the hood open so there is no way I would be able to drop it closed. I always push down on the crest to avoid finger prints.
pelon 10-30-2014 09:32 PM
Hood
The front I push to close, the rear lid will close if I drop it.
nettles503 10-30-2014 10:54 PM
I close my hood by pushing down lightly with one hand on either side of the crest, fingertips spread. That's how the dealer told me I should close it. FWIW.
porwolf 10-30-2014 11:29 PM
Porsche hoods need the be pushed down because they are held up by the hood struts. I always push down my hood with the back of my fingers and I place them very near the bottom of it. That's my SC. On my earlier Porsches I pushed down where near the front of the hood right where it curves down. Never had a dent in my hoods.
gamin 10-31-2014 03:21 AM
Takes an extra push, but NEVER on the hood crest. You will end up with a pushed in hood crest. I put both hands left and right of the crest and push down smartly.
theiceman 10-31-2014 06:00 AM
i NEVER push down on the hood crest . in my opinion thats too much force in one small location . just on the edges about 6 inches left and right of the crest is fine.
tharbert 10-31-2014 06:41 AM
Wait till next month. This'll change! :)
Jose_JGC 10-31-2014 06:56 AM
Like everyone else here I too give my 911’s hood an additional push to close. I believe this is the only way to do it for cars with hood struts.
Jdub 10-31-2014 07:02 AM
The definitive response:
Front: Spread both hands wide, on either side of the crest, close to the lip of the hood where underside support is best, and gently but firmly push down.
Rear, right-handed owner: With the left hand holding the hood at level, place the right hand on the grille, and then let go with the left hand while pushing down with the right hand.
pmax 11-05-2015 11:03 PM
Well, according to this video (7.30) , the crest was designed to be used ... for the 993 at least.
https://www.youtube.com/watch?v=tVm09RAU6KQ
DRACO A5OG 11-06-2015 01:11 AM
Whoa, kinda of an old thread, no? :D
One can adjust it so you do not have to push so hard to close. As long as it clicks on the final latch. it will stay nice and locked.
Pazuzu 11-06-2015 07:27 AM
Why not just move the latch with your fingertip, like you do when you open it? Then it takes zero effort to latch closed, no bendin', no pushin', no distortin', no nothin'.
bdisco 11-06-2015 07:57 AM
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&u act=8&ved=0CBwQtwIwAGoVChMIoOja95P8yAIVwvI-Ch1sEgoU&url=http%3A%2F%2Fwww.youtube.com%2Fwatch% 3Fv%3Dphrzll4Us9w&usg=AFQjCNFsk7FZtbeVSZ99DvcMLxjP UotSmw
http://i.ytimg.com/vi/phrzll4Us9w/hqdefault.jpg
:eek:
T77911S 11-06-2015 08:25 AM
i push at the front edge where the hood is stronger, dont want to put a dent in it.
universeman 11-06-2015 09:42 AM
Fingertips to left and right of the crest is how I do it. I think that's the recommended way. Light pressing on the crest is probably fine, but too much and you'll get a dented hood.
gtc 11-06-2015 10:42 AM
Press down directly over the latch.
Pressing on the crest makes no sense whatsoever.
