-   -   Ultimate 3.6 conversion 993tt (http://forums.pelicanparts.com/porsche-911-technical-forum/836544-ultimate-3-6-conversion-993tt.html)
jevvy 10-31-2014 03:04 AM
After doing a 3.6 into an 89 911 and a Vram into a 964 I really wanted to try a tt transplant. I'd been hunting for an engine for years and one came up fairly local to me - be rude not to:
http://jevvyg.com/files/993tt-1.jpg
Engine came from a car that had been in a bit of a shunt - I saw the car and the documents (60k miles FSH) so decided to bite the bullet and get it bought. I got the loom, ECU, intercooler and gearbox, this is the car its going into:
http://jevvyg.com/files/lhd964-10.jpg
jevvy 10-31-2014 03:07 AM
I'm going to resist a full rebuild until after I have fitted it but have been spending some time tearing it down so I can check everything and do all the seals etc, below is a selection of pics from this process:
As collected
http://jevvyg.com/files/993tt-2.jpg
Removing flywheel to fit engine stand mount
http://jevvyg.com/files/993tt-3.jpg
Unfortunately the mount wouldnt fit with the alloy charge tubes so plan B was needed
http://jevvyg.com/files/993tt-4.jpg
Looks like it should fit - limited space though.
http://jevvyg.com/files/993tt-5.jpg
New home for a few months
http://jevvyg.com/files/993tt-8.jpg
jevvy 10-31-2014 03:08 AM
Removed SAI system
http://jevvyg.com/files/993tt-10.jpg
Removing the alternator and fan
http://jevvyg.com/files/993tt-11.jpg
Heat pipe removal
http://jevvyg.com/files/993tt-15.jpg
Then the AC/oil pump bracket
http://jevvyg.com/files/993tt-17.jpg
Oil pump drive
http://jevvyg.com/files/993tt-18.jpg
Oil pump - how cool is that!
http://jevvyg.com/files/993tt-19.jpg
Removing intake & power steering pump removed
http://jevvyg.com/files/993tt-20.jpg
Intake removed
http://jevvyg.com/files/993tt-21.jpg
Kinda clean
http://jevvyg.com/files/993tt-22.jpg
First heat exchanger off, put up a fair fight :)
http://jevvyg.com/files/993tt-24.jpg
993 TT heat exchanger compared to a 993 NA heat exchanger:
http://jevvyg.com/files/993tt-25.jpg
993 TT gearbox, need to remove the viscous coupling and sort a different nose cover. I think I also need to update the mount slightly to run in 2WD mode which I need to look into a bit more:
http://jevvyg.com/files/993tt-26.jpg
Second heat exchanger off, put up much more of a fight than HE #1.
http://jevvyg.com/files/993tt-27.jpg
Looks almost like a normal 3.6 now:
http://jevvyg.com/files/993tt-28.jpg
Clean up/check of the intake:
http://jevvyg.com/files/993tt-29.jpg
Half way there:
http://jevvyg.com/files/993tt-30.jpg
jevvy 10-31-2014 03:09 AM
Never realised the bottom crossover chamber on a TT engine is blanked off and effectively an empty chamber where the resonance flap would be on an NA motor - whats all that about?
http://jevvyg.com/files/993tt-31.jpg
Quick clean up of the HE's:
http://jevvyg.com/files/993tt-32.jpg
Found some rebuilt standard turbos:
http://jevvyg.com/files/lhd964-11.jpg
http://jevvyg.com/files/lhd964-12.jpg
Bit more time today to have a play and a think...
Tried the intercooler in the track IB which has a ducktail:
http://jevvyg.com/files/lhd964-13.jpg
Seems to fit just fine without the big tray that is fitted to it in a 993.
A snap from the side makes it look like it will fit with the duck if I hack a few chunks out of it (the duck not the IC):
http://jevvyg.com/files/lhd964-14.jpg
http://jevvyg.com/files/lhd964-15.jpg
So with a bit of work I think the duck is a go-er. Here the IC is roughly placed in the spare duck I have:
http://jevvyg.com/files/lhd964-16.jpg
Think its a case of fit the engine, mark where the duck needs a trim then try to make up a nice seal of some sort to make sure as much air as possible is getting drawn in through the IC.
jevvy 10-31-2014 03:10 AM
So I was checking the intake gasket thingys the other day and spotted some debris:
http://jevvyg.com/files/lhd964-22.jpg
Hmm - that cant be good so decided to pull the cover:
http://jevvyg.com/files/lhd964-23.jpg
http://jevvyg.com/files/lhd964-24.jpg
Hope I can remember where all this goes:
http://jevvyg.com/files/lhd964-25.jpg
http://jevvyg.com/files/lhd964-26.jpg
http://jevvyg.com/files/lhd964-27.jpg
All went well apart from these little tinkers:
http://jevvyg.com/files/lhd964-28.jpg
http://jevvyg.com/files/lhd964-29.jpg
Bit more tinkering over the past week or so, firstly some bad news: Check this little tinker out :(
http://jevvyg.com/files/lhd964-30.jpg
http://jevvyg.com/files/lhd964-31.jpg
From the state of the break area it looks like it happened a while ago. Its non load bearing so I think I'll try a macGyver repair first to save yanking the chain box - any other ideas?
Another lucky find:
http://jevvyg.com/files/lhd964-32.jpg
I think I'll send them off for a refurb or maybe just track down some new ones.
Parts stock is gathering pace, amazing how expensive all the little seals and stuff are but would be silly to not do them while I'm at this stage
http://jevvyg.com/files/lhd964-33.jpg
Ready for the next phase:
http://jevvyg.com/files/lhd964-34.jpg
Sorry for the blurry pic but does anyone know if the fingers on the stainless air diverter jobby are supposed to line up with the gaps or the fins - I seem to have a mixture of both?
http://jevvyg.com/files/lhd964-35.jpg
Valve cover off:
http://jevvyg.com/files/lhd964-36.jpg
jevvy 10-31-2014 03:11 AM
Cams look clean:
http://jevvyg.com/files/lhd964-37.jpg
Cleaned up ready for new gaskets on the valve cover:
http://jevvyg.com/files/lhd964-38.jpg
New(Bosch) vs old(Beru) plugs - slight variation in part number (FR6LDC vs FR6LDU)
http://jevvyg.com/files/lhd964-39.jpg
Bottom valve cover off:
http://jevvyg.com/files/lhd964-40.jpg
Chain box cover removed ready for new gasket and o rings:
http://jevvyg.com/files/lhd964-41.jpg
Chain box looking fairly clean:
http://jevvyg.com/files/lhd964-42.jpg
I was tempted to tear into it further but after a chat with Ray @ Northways and the fact my labour is free I'm gona just do all the perishable seals and chuck it in and see what its like.
group911@aol.co 10-31-2014 04:13 AM
The cam seals and chain box to case seals are a normal source of leaks.
Competizione 10-31-2014 05:15 AM
Fantastic project... Looking forward to following progress. Best of luck.
jpnovak 10-31-2014 06:17 AM
This is going to be an incredible build. Something I have had in my head for a while. I had planned something similar until the price of 964s made them out of budget.
Is your 89 a C4?
sand_man 10-31-2014 07:07 AM
Subscribe....
jevvy 10-31-2014 07:10 AM
Thanks Bob, Chain box to case and cam seals are very dry so I'm not going to poke that bear for now. I'm ditching the power steering drive and fitting an electric pump up in the front trunk so that will eliminate the leaks at the other end of one of the cams too.
Thanks, should be pretty mental. The ECU is the 430bhp version too which was a pleasant surprise when I picked the ECU up shortly after collecting the engine.
Is your 89 a C4?
Its a 90 C2, bought just before the prices went mental. With it being a C2 I need to fettle the nose of the tt gearbox and look at the mount. Also need to deal with the lack of speedo feed on the 993 box but that shouldn't be too hard I dont think.
sand_man 10-31-2014 07:23 AM
It has been a few years, but this was one of my all time favorite builds...EVAR! Complete perfection! Not sure if he (LARennsport) is still on the boards, but worth a shot if you run into any snags or have questions:
http://forums.pelicanparts.com/porsche-cars-sale/548883-1-1-964r-turbo.html
http://forums.pelicanparts.com/uploa...1276984536.jpg
sand_man 10-31-2014 07:29 AM
I might have some additional pictures on an old computer. I will look...
And on Rennlist he is LA964RS:
http://rennlist.com/forums/964-forum/435168-finished-964tt-pics.html
jpnovak 10-31-2014 08:49 AM
Why not stick with the stock G50? It should handle that 450HP level with no problem. Plus, not fitment issues since you just bolt it up to the engine.
I do realize the gear ratios are different but that might not be a bad thing. Not really a lot of places in UK to really explore the top of 5th!
Just trying to make the project a little easier.
jevvy 11-02-2014 03:51 AM
Jeff - thanks for the links on the white car, if you have any more details/pics im all ears.
Jamie - if i get the engine done before i find a new nose for the tt gearbox i will probably do just as you suggest, should be fun with either gearbox :)
al lkosmal 11-02-2014 07:41 AM
I'm going to watch this one.................I haven't entered the turbo world yet, but .............I'm get more interested when I see a cool DIY project like this.
regards,
al
