Shock tower nut torque down help
I'll try again without predictive text!!
I am having trouble trying to torque down the front shock tower nut, when you do the shock starts to spin and I cannot see a way to lock it off to tighten it.
Thank you
Nigel
Old 11-01-2014, 01:26 AM
rnln's Avatar
if I remember right, there is a little notch on the washer. Put something there to hold it against the chasis while you are turning the nut, a short socket will work
Fat butt 911, 1987
Old 11-01-2014, 02:43 AM
River Rat
Dave 86 930 Fl's Avatar
If you have a compressor, try an air impact wrench.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 11-01-2014, 04:28 AM
OffCamber00's Avatar
This. Impact wrench is the ticket.
Mat P
1988 911 Carrera
Old 11-01-2014, 04:36 AM
Thank you yes i have a compressor so will do
Ta
Old 11-01-2014, 03:36 PM
