Weber Spec's for 911R (1967)
Hi
Does anybody know the weber set-up for the 911R?
I know they used Weber 46 IDA's, but how were those jetted?
Venturies, idles, mains etc.
regards
Jon S
Old 11-04-2014, 07:53 AM
1QuickS's Avatar
  • 42mm main venturis
  • tall auxiliary venturis
  • 170 mains
  • F24 emulsion tubes
  • 145 air corrections
  • 70 idle jets
  • 80 idle air correction jets
  • 40 accelerator pump inlet check valve exhaust port dia
  • progression holes from bottom to top are: 80, 80 & 160
  • pump rod for accelerator pump is fixed-length (non-threaded)
  • cam lever for accelerator pump is short arm version
  • throttle shafts thinned for reduced cross-section at wide-open-throttle
  • throttle lever arms are short version compared to OEM lever arms
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-04-2014, 03:48 PM
Wow,
Thanks for details Paul!!
Old 11-04-2014, 11:16 PM
