Hbrand
hbrand's Avatar
Why do Porsches have Tails??
I think they are great looking without those tails.
And with some after market tails, rainwater wets the ignition and gues what happens!!!
thanks, harold
Old 10-10-2002, 04:00 PM
Tails increase stability and you need new iginition wires my friend
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-10-2002, 04:11 PM
1. I agree most 911 look better sans wing, but there are others that need the down force.
2. Mines got a great big vent on the deck and it rains ALL the time no prob with ignition.
3. Your in florida. rain?? its meant to be the sunshine state
Old 10-10-2002, 04:13 PM
Mark Wilson
Guest
Posts: n/a
According to the guys that know, the tails will significantly reduce lift on the rear end of the car adding stability at speed. There are some charts posted that show the effects of the different tails. Do a search and I bet you will find it.
Mark
Old 10-10-2002, 04:27 PM
nostatic's Avatar
The previous explanations seen here discuss how that the tail reduces lift rather than increases downforce (semantics?). At high speeds, the car wants to lift off...front and rear spoilers help keep that tendency at bay.
autobonrun's Avatar
When I bought my SC in 1984, I found at about 130 mph, it would move left to right without steering input from me. It wasn't unmanageable, but the front end felt light.
I added the front spoiler and tail the same year and the car became very stable. Little movement at speed and you could feel the response better when you moved the steering wheel.
If you are not going to drive at high speeds, then you can keep the non-tail look with little degredation in handling. I've heard that the impact is greatest at speeds above about 80mph.
On hind sight, what I should have done was kept my stock hood and bought another to mount the spoiler on. Then I could have shifted back to the original look in my old age.
No problem keeping the front spoiler and running without the one on the back. Vice versa is a no-no.
Old 10-10-2002, 04:31 PM
WydRyd's Avatar
AND then there's the turbo 911's! They NEED a tail to accommodate the air-to-air intercooler
Kills two birds with one stone really. Provides housing for intercoolers and also added down-force and stability at speed
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-10-2002, 04:57 PM
GoodMojo's Avatar
On an intercooled 930, the tail is almost necessary as the increased height required by the intercooler would've made a tailless version pretty funky visually. I suppose a grill mounted intercooler may be possible but the plumbing would probably be too difficult to shoehorn in there.
Wade
'88 930 Slant Coupe
Old 10-10-2002, 04:59 PM
s_wilwerding's Avatar
Does a tail on a regular 911 (not 930) keep the engine any cooler? It seems to me that the tail directs more air into the engine compartment than having the sloped back.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 10-10-2002, 07:04 PM
Team California
speeder's Avatar
Steve, Yes, that is correct. Several members here have added a tail and noticed lower temps w/o any other modification, and the reason that you stated is correct.
Denis
Old 10-10-2002, 07:57 PM
nostatic's Avatar
Denis, how goes the engine?
Old 10-10-2002, 08:29 PM
