-   -   Seine Gate install and Shift housing refresh (http://forums.pelicanparts.com/porsche-911-technical-forum/836884-seine-gate-install-shift-housing-refresh.html)
Neilnaz 11-06-2014 04:52 PM
And now for another test drive!!!
I installed the gear shift mechanism after finishing work (lucky me 1/2 day on a Friday!). It took 2 minutes to install. All gears selectable and with nice precise feel. I will have to put some miles on the car just to make sure all is optimised.
I already love the feel.
Cheers, Neil
cknaak 11-06-2014 08:54 PM
Nice! I look forward to hearing how it goes once you road test it.
Did I read your post right? You epoxied the gate on vs welding?
Just making sure I know what I'm getting into before I do this.
Neilnaz 11-07-2014 04:22 PM
Hi yes I epoxied using a powder plus glue product. I tested by trying to yank it off after 24 hours and it isn't going anywhere. It is just as neat as the other gate arm. The reason I decided to try epoxy was that I can manage that myself. Otherwise I would ask a mate and wait a few days.
All the best with your install.
I will update with road test results.
Cheers Neil
Neilnaz 11-18-2014 02:26 PM
Conclusion to this:
I love the feel of the Seine Gate shift:
It gives certainty to the gear change. The spring-loading means you know exactly where you are
It looks great
It keeps standard Porsche components
I needed to adjust my coupler slightly - this was required anyway. I added Lithium grease to all moving parts. While I was undertaking this work I also fixed the broken part of the gear knob that annoyed me using the epoxy, sanding and painting. It is difficult to tell that there was a chunk missing previously.
I have been enjoying driving the car for the last few days.
http://forums.pelicanparts.com/uploa...1416349455.jpg
Cheers, Neil
Flojo 09-28-2017 02:07 PM
Originally Posted by Neilnaz (Post 8340015)
I drilled and installed the spring mechanism:
http://forums.pelicanparts.com/uploa...1415219154.jpg
I understand this spring makes the use of the oem rubber boot obsolete?
Pity, as I was about to order.
911pcars 09-28-2017 02:32 PM
The factory rubber boot will work with a slice at one of the bellows bends. Described here:
Seine Systems > Gate Shift Kit Installation Overview
A leather shift boot provides lots more room and is one option.
Sherwood
Seine Systems
uwanna 09-28-2017 02:39 PM
I have the rubber boot on my Seine unit with absolutely no problem. I did not have to cut the opening as some recommend. The boot just shows a slight bulge where the spring unit is located.
cabmandone 09-28-2017 04:18 PM
I had the boot on mine for a little while but went back to the leather cover in the console.
A horse with no name 09-28-2017 09:48 PM
Hi...Does a JWEST-aka- Renshifter work on the same premise as a Seine?...If so, any Pro's & Con's between a JWEST vs a Seine that you may know of?
Thanks in advance!
PS - Does the factory leather boot cover the Seine for a stock look? - Or?
uwanna 09-29-2017 07:17 AM
Originally Posted by A horse with no name (Post 9755819)
Hi...Does a JWEST shifter work on the same premise as a Seine?...If so, any Pro's & Con's between a JWEST vs a Seine that you may know of?
Thanks in advance!
Well for me, the biggest Pro for the Seine shifter versus the JWEST is the price. $160 Seine VS $560 JWEST.
I have never experienced the JWEST, however I have a Seine with a factory short shift kit and a 6" stick extension. This setup shifts "like butter" and I can't imagine the JWEST could be that much better! Yes you can use the leather boot with the Seine.
A horse with no name 09-29-2017 03:36 PM
Thanks for the info uwanna - Whoa!...$400.00 is quite a difference, to say the least ay!
JJ 911SC 09-29-2017 04:26 PM
And the instruction shows where to do a small cut for the spring top to stick out.
But the boot weigh is a drag so I removed mine and the weigh saving give me a Power Boost of about 0.005 HP.
RSBob 09-29-2017 10:47 PM
Am on my second car with a Seine. After I sold the first and got another with a 915, there was no way I was going to tolerate the slop, so got another and haven’t missed a shift in 3 years. Good stuff for cheap.
A horse with no name 09-29-2017 11:13 PM
Thanks RSBob!...Any thoughts on a Wevo vs a Seine?
RSBob 09-29-2017 11:24 PM
Don’t know about Wevo, but people who have had both Seine and Rennshift prefer the later. But when you compare prices, the Seine is a bargain and it works just fine.
