chip tuning in the Bay Area
Can anyone recommend a San Francisco Bay Area tuner who routinely does 911 Bosch Motronic mods? I need a custom chip for my 3.2L with 964 cams, porting, K&N cone, B&B dual out & cat bypass. I do not want to replace the Bosch brain... so the let's-replace-your-computer-with-this-$2000-wingding!! program (a la Bauer) won't work for me.
I have an early '84 with a soldered chip, so I need someone to solder in a socket. I've been considering Autothority, but truthfully I don't like the distance. I'm interested in someone local so I can get the car on a dyno and re-burn the chip if necessary.
Thanks in advance,
~Hugh
'84 Carrera
Old 09-19-2002, 02:10 PM
Eric Coffey's Avatar
Porsche Crest
If I were you, I would make the hour (or so) drive up to The Racer's Group at Sears Point (Sonoma). They have a huge facility and two dynos. Burning a custom chip for your exact application would be no problem. They also are the authorized distributor for the Unichip "piggyback" ECU's/chips, if you decide to go that route. Plus, you will get to see what a Le Mans winning team's shop looks like!
Check it out here if you have a few minutes: www.theracersgroup.com
Old 09-19-2002, 02:35 PM
tobluforu's Avatar
Like said above, go to the racers group. Great group of guys-the unichip kings. They will hook your baby up and get to purr like never before
Old 09-19-2002, 02:56 PM
jhugh:
Did you ever get a new chip for your car? results?
Old 10-11-2002, 11:26 AM
BYantzer's Avatar
I believe that S car Go can help. 415-485-6026 ask for Rob.
Brad Yantzer
81 SC
87 944s (dead, burnt it up)
Old 10-11-2002, 12:18 PM
Hey folks,
Thanks very much for the recommendations. I've been a bit delayed on my rebuild, so I haven't yet gotten to the chip. I'll definitely be calling S-Car-Go and Racer's Group. But Unichip is exactly what I don't want to do... the $2K wingding. I'm looking to spend no more than around $800 on reprogramming.
I will post my results when I get her running.
Cheers,
~Hugh
'84 Carrera
Old 10-11-2002, 12:31 PM
