Exhaust smell in the car
Today it was 40 degrees out and I had a real need for a drive. I noticed that when I turned the heat on there was enough exhaust fume smell in the car to crack the window. Everything in my car is basically new, SSI's, muffler, etc. Any obvious reason that I am missing? Thanks
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch R Gruppe Member #626 |
Reiver
Exhaust fumes or oil smell?
Can't imagine you having 'fumes' in the car with a sealed system (SSI's and proper hose). If you use the additional electric booster fan in the engine bay it is easy to pick up that hot oil smell if things are a bit grungy. Actually, since the cooling fan is sucking air from the engine bay anyways the same thing can happen. Clean engine, no smell.
De Oppresso Liber Strength and Honor 5th Legion |
It was definetly exhaust. The engine and bay are spotless. Sounds like I may have to check out the SSi's
