-   -   Stack 430 Tachometer with Bosch CDI 6 pin (http://forums.pelicanparts.com/porsche-911-technical-forum/836991-stack-430-tachometer-bosch-cdi-6-pin.html)
manu72S 11-03-2014 11:41 AM
Hello
Is it possible to use Stack 430 as tachometer with a 6 pin CDI box ( Bosch 004) ?
I have wired TD pin directly to orange Stack wire but the needle didn't move at all. The orginal tachometer was useable without any problem.
Thanks for your help
porschetub 11-05-2014 09:24 AM
Originally Posted by manu72S (Post 8336753)
Hello
Have you a selector on the back of the tacho for 4,6,8 cyl options,is that set right?if it is you will then most likely need to buy a tach adaptor,our host sells one.
My understanding is the factory VDO tachs are matched to the engine/ignition of that year car,most modern tachs have that adaption in the selector,don't know about your brand however.
manu72S 11-06-2014 01:13 AM
Hi
Thanks for your reply ;)
No adapter
My tachometer ( 911 641 301 03) is totally functional with the Bosch 6 pin CDI ( 0 227 300 004). But when I put my Stack there is no needle movement.
I can say : my Stack tachometer is functional with Bosch 3 pin CDI ( 0 227 200 001 ) too.
Nicke N 06-09-2020 03:41 AM
Lifts an old throad.....
I have the same problem..I have a Stack 430 and 2x6 pins boxes.With the black/Purple to the Orange lead it dosent work.Also try,by suggestion to put aST697 speed pulse sensor to the coil,but I think I "burn" it...So the Q is.....Anybody using Stack on a Porsche.How do you connect it..?
manu72S 06-09-2020 10:32 PM
Hi
3 pins and 8 pins boxes there is no problem with Stack
For 6 pins you need to modify it ( diode D8)
Manu
Nicke N 06-10-2020 06:35 AM
Thanks for answer.Did you mean to modify the CDI-box....?
Jonny H 06-10-2020 12:58 PM
Originally Posted by manu72S (Post 8340889)
Hi
No adapter
3 pin CDI boxes do not have a tacho drive. On 69/70 cars the tacho is driven from the coil voltage (400V). Up to the last 3 pin cars (1976) the tacho is driven from the points.
AndrewCologne 06-11-2020 03:47 PM
Seems that Stack needs a 0v/12v switching pulse width signal as stated by Gerberding:
https://www.911-hkz.de/TDSignal.htm
Furter below you can see the Stack regarding part.
Its german but todays google translator output is quite ok.
BR
Nicke N 06-14-2020 08:34 AM
..Thanks..
