Porsche 911 Ring & Pinion
Hi
The time has come to rebuild the 5 speed gearbox of my 1972 911 2.4 T-E series (chassis 911 310..). My mechanic says that the gears are good but I need a new pinion&gear, plus obviously: bearings, syncros and all gaskets/seals. I am looking around for a new or good second hand pinion&gear set, but see there are various solutions out there to choose from and I am a bit confused on what we can use. The pinion&gear set I have on the original gearbox has 31 and 7 teeth. Can I have the stronger 31- 8 set installed or do I have to stick to the original set? FYI the engine was been completely rebuilt with high compression pistons, modified E camshafts and S MFI pump shaft. I plan to use the car for amateur hill climbs here in Tuscany. Does the limited diff improve a lot the drive? Do you suggest any particular limited diff upgrade? Any other suggestion would be highly appreciated, and remunerated with some good wine if you pass in Tuscany ![]() All the best, Alain ![]()
I add another picture of the head of the pinion. I believe this is for the mechanical speedo. Any help would be appreciated!
Hi I am just making new Ring and pinion slightly lower ratio @ 5:1 7/35 or I probably have a std 7/31 mech drive set if you get stuck
Neil
To Finish First - First you have Finish CHECK OUT WWW.bsmotorsport.co.uk |
Hi BSMotorsport
7/35 sounds perfect. Does it fit in my gearbox without modification? Do you suggest also the limited diff upgrade? Last edited by ale911; 11-02-2014 at 04:20 AM.. |
Can I install 31:8 pinion & ring without modifications?
Originally I have the 31:7 with mech speedo. |
gearhead
There's only a few gearboxes that ran an 8:31 with mechanical speedo. It's a very limited production window. You may be shopping a while.
It's also a tricky setup. The ring gear flange thickness and offset is different, so things get a little funky when shimming it for backlash. |
Ok, thanks
Are all 7:31 the same? i.e. if I find another 7:31 is the setup complicated as well? |
Will all 31:7 with mech speedo pinion&ring set fit on the 915 gearbox? Or is it tricky?
gearhead
Sorry. Wasn't around much yesterday. You are still going to need a professional to fit any replacement ring and pinion. However, all 7:31s are the same as each other and don't have the weird shimming of an 8:31 in your box. But without a 385 bar, you cannot properly fit a replacement by yourself. It is not a DIY job.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks!
I see there are around for sale various 31:7 p&r from the 914. Would these work? |
gearhead
Nope. The 914 gearbox is 901 based.
you mention hillclimbs...then a longer ratio like the 31:8 is the opposite of what you would want.
4.43:1 vs 3.88:1
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Thanks Matt, so I have to look for a 31:7 for 915 gearbox.
Ganun, I agree, better off to find a 31:7. The 35:7 tempts me, but will probably drive me crazy if I ever had to drive on the motorway. After all, I think I will go for the stock 31:7 but would like to add a nice limited slip diff. Any suggestion on type and make for the 2.4 915 5 speed gearbox? |
