-   -   Another Brake Warning Light Challenge (http://forums.pelicanparts.com/porsche-911-technical-forum/837297-another-brake-warning-light-challenge.html)
steely 11-10-2014 04:18 PM
Originally Posted by wwest (Post 8347142)
PS is correct.
Can EVERYONE chime in.... who knows, says, different??
The brake warning light is on ONLY for e-brake or low brake fluid!!!
Or in your case possibly an alternator over voltage indicator.
Confirmed for 84-89 anyway - assuming the bentley schematics are correct, both the brake fluid level switch AND the e-brake switch wires go to the same exact spot as each other to the parking brake light.
Dunno for an SC.
scarceller 11-10-2014 05:41 PM
Unplug the fluid level sensor, does the light go out?
SCadaddle 11-10-2014 06:54 PM
As per my '82 SC owners manual there is no brake fluid level warning.
http://forums.pelicanparts.com/uploa...1415674415.jpg
tazzieman 11-10-2014 07:50 PM
http://www.pelicanparts.com/catalog/...sten_belts.JPG
Isn't there a little circuit board thingy inside here?
steely 11-10-2014 08:40 PM
Yes, there is, Tazzie.
jhmol 11-11-2014 09:13 AM
Darkly-Noon wins my life-long admiration. Simple. Too the point.
I replaced my left brake light and voila. Brake lights work! Brake warning light stays out (so far)! Brakes work great!
I know it's early, but I heard the Hallelujah Chorus singing! Thank you all. On to my next challenge... 3rd gear gear shifter rattle.
John
Darkly-Noon 11-11-2014 05:21 PM
Woo! Glad the solution was simple and cheap...
John
markivtruck 11-12-2014 12:04 AM
replace stop lite switches on master cyl.
