porski's Avatar
Send a message via AIM to porski Send a message via Yahoo to porski
Going toppes
I have a 79 911sc targa,widebody. I`m thinking of installing a convertible kit. I what i need to know is how much work is it going to be,(hours). and or has anyone done a conversion. Are there any books around about this topic. Thanxs a head of time
1992 chevy blazer
1979 911sc targa,wb
Old 10-20-2002, 01:01 PM
Crusty Conservative
silverc4s's Avatar
Is your car a factory widebody??? If so, it has some rarity as a model, which you will lose by the modification you are considering.... If not, and it has been "widebodied" in the aftermarket, then cutting the targa bar will likely not make things much worse resale wise.
It does have a real detrimantal effect on stiffness to remove the rollbar and rear glass, in a car that is not very stiff to begin with. Your wide wheels and such will magnify the flexibility of this car, and it will shake, rattle and (well, it probably won't actually roll ).
My advisethen. If it a pretty nice car now, sell it and find a nice early cab if that's what you want...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-20-2002, 01:23 PM
porski's Avatar
Its a aftermarked steel wide body converion. Thanxs for your help
Old 10-20-2002, 01:34 PM
Tho Fitzpatrick who is on this board has done a widebody targa to cab conversion.
He documented the procedure with pictures HERE
Old 10-20-2002, 01:45 PM
A Quiet Boom's Avatar
Anyone gone the other way and converted a targa into a coupe? I have an aftermarket widebody targa project and am considering making it a coupe instead. I already have doors and glass so I'd just need the top sheetmetal and some serious patience with my Tig welder.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 10-20-2002, 05:42 PM
I had about 12 amateur hours into cutting the targa bar off, installing the top mounts, and fitting the top. I went really slow to make sure I got everything right. Then another 4 hours to do the finish work, ie clean up and paint the welds, install trim, roll bar, etc.
BTW, I have an extra set of original cab pillar mounts, if you're interested.
Old 10-20-2002, 06:14 PM
Crusty Conservative
silverc4s's Avatar
I thought that the rear fender shapes for the taga were very different than the coupe - in the upper areas. Not true??
Bill
Old 10-21-2002, 06:43 AM
