 Pertronix with no CDI
		I'm trying to track down a misfire problem with my engine.  I've worked on the CIS until there seems little opportunity for improvement.  For various reasons I had no faith in my original ignition (CDI, Bosch distributor), especially the coil, and decided to replace it with a Pertronix for diagnostic purposes.
	SO I avoided using the CDI and existing coil. This is what I did: http://forums.pelicanparts.com/uploa...1415267278.jpg The engine runs OK after setting the timing. It seems a bit angrier (which is good) and I'd swear that it's running hotter. BUT there is still a bit of a misfire and the tach is jumping a lot and possibly indicating a bit high. The tach jumps may be linked to misfires. I haven't driven it yet. Does my wiring look OK? Any ideas for what causes the jumps? Would it be stupid to try running wires all the way from the battery?  |
 Well, I guess that silence is good!  Nobody has said "Oh my God - your car is going to blow up!".
	As an afterthought I plan to add a diode around where the green box is on the old points lead. I only need the current to flow in one direction: from the tach to ground through the Pertronix, so it might be a good idea to make sure that it can't go in the other direction.  |
 Why did you remove the CDI?
 I think that my CDI is good - it whines away happily - but I wasn't sure.  I wanted to remove the entire original ignition system and go from there.  I may well add the CDI back in, although I saw a note in the Pelican product catalogue that the Ignitor II is not the one to use with CDI.
 Hi Folks
	I could really use some help with this! Since changing to the Pertronix my tach reads strangely: when I am idling the tach says 2000 RPM. Then when I get up to about 6000, it jumps back to 4000 and starts again! It worked fine before the change ... although I think the engine is running much better, probably because of the new coil.  |
 The reason for CDI is a hotter spark and quicker recovery time after the coil fires at higher RPMs.
	For lower RPMs a Kettering ignition will work just fine as long as the coil is designed for the service.  |
 I had exactly what you describe when fitting a Pertronix ignitor to my '73 MB 450SL. (Dont think there is any connection with the misfire.) It was recommended that I simply install an 11.5K ½ watt resister, but I never got round to it before I sold the car. I was going to buy a small tach adapt box (from Bob Ashlock ??) There is a good description of the unit somewhere in past posts. Peter PS: Try some NGK Iridium plugs  |
 A while ago I follow this videos.  It cleared a lot of things.
	And it was a similar installation without CDI. Completely eliminated. Needed a tach adapter though... My distributor had to be rebuilt because of the mechanical advancement. It would work well and then went completely out of time. But that is a different issue. Hope it helps Electronic Ignition Install - 1967 Porsche 911S (Part 1 of 3) - YouTube <iframe width="560" height="315" src="//www.youtube.com/embed/7CTKur8XHBw" frameborder="0" allowfullscreen></iframe>  |
| All times are GMT -8. The time now is 01:27 AM. |
