red911's Avatar
Post Clutch Pedal
Looking for a reason and solution why my clutch pedal does not come all the way back even with the brake pedal? I recently had a new cable installed.
Bill
83 911SC Targa -174K miles
Old 09-20-2001, 12:06 PM
Clark Griswald's Avatar
Post
Several:
1) Horse shoe spring is weak - replace
2) Clutch pedal spring is weak - replace
3) Clutch is misadjusted - adjust
4) Pivot shaft for the arm connected to the cable at the trans side is sticking - remove arm, clean up pivot and lubricate
5) Pedal bushings worn or oil soaked - replace
Could be any one of the above or a combination. The springs and bushings can be bought for under $100 total, everything else can be done for free.
Chuck Moreland '86 Cab - "Sparky", '77 Targa - "Sweet Pea"
[This message has been edited by Clark Griswald (edited 09-20-2001).]
Old 09-20-2001, 12:10 PM
Post
It's a matter of adjustment. If I remember correctly, to get the pedals more even, you would need to "loosen" the adjustment at the tranny end of the cable. That would cause the clutch pedal to move closer to you and would cause the "take up" point on the clutch to be farther into the pedal travel.
Old 09-20-2001, 12:12 PM
