wolds's Avatar
brake caliper refinishing
I'm in the process of going through the brakes on my 83SC. I've got everything apart and getting ready to send my backing plates, e brake and misc nuts and bolts off to get zinc plated and was wondering what if any finish would have been on the calipers themselves. I was going to just clean them up and give them a coat of VHT caliper primer and color, but then thought that I could get them zinced also. Any thoughts?
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-02-2013, 07:32 AM
89PS911's Avatar
Try PMB Performance
If you are going that far, you should have your calipers rebuilt if you have not done that already. I sent mine last winter to Eric at PMB Performance (pmbperformance.com). They came back completely rebuilt and coated in a dull gold finish. They look fantastic and operate the same (with the new rotors, pads, pins, clips, and stainless lines that I installed).
Old 01-02-2013, 08:03 AM
Innocent Bystander
Since you're the do-it-yourselfer type, go to Caswell Plating (Plating Kits Electroplating Kits Aluminum Anodizing Kits Powder Coating Systems Metal Polishing And Buffing Supplies - Caswell Inc) and look at some of the coating options available there. Even if you decide to spray them with VHT, you'll still see many things on their website that you'd like to have.
Old 01-02-2013, 08:21 AM
wolds's Avatar
Good point. I don't have a problem separating the caliper halves. I don't think the caliper rebuild kits come with the orings that go between the caliper halves so I would need to find them.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-02-2013, 08:31 AM
Mo money = mo parts
There different view points on separating the halves. I personally would not as the haves can be challenging to seal and it is't necessary to rebuild the pistons. Also, Porsche recommends not splitting. If you get a rebuild kit, it will only include piston seals and boots, you would need to source caliper half seals elsewhere.
I sprayed mine with caliper paint a few years ago. They looked fine, but it would be something you would need to repeat periodically if appearance is important.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 01-02-2013, 09:46 AM
moneymanager's Avatar
Any rattle can will produce an acceptable finish that will last for an amazingly long time, even if you race and really use your brakes. Krylon, Rust Oleum, they all work great unless you're someone who is hyper-demanding, i.e. polishes his valve caps every week. And you can have any color you want!
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 01-02-2013, 10:49 AM
wolds's Avatar
Thanks for the info, I'll probably go the VHT route as I already have a can of cast aluminum.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-02-2013, 10:52 AM
wolds's Avatar
Greg brought up the concern about or need to split the calipers. Have others found the same issue with getting them to seal properly? I have contacted yellow zinc plating in New Jersey to take care of the plating. I don't want to open a can of worms here, but I want to do the job right.
Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-02-2013, 04:18 PM
You'll get a lot of views but I can't imagine what you gain by opening the caliper, UNLESS you are plating. What is inside that won't be removed by a bit of solvent? Correction: I see you are plating not painting. Ignore this.
jhtaylor
santa barbara
Old 01-02-2013, 04:26 PM
47silver's Avatar
splitting calipers
i split mine.
You need the special socket to take them apart,, it is not a torx.
You get the seals from a porsche dealer.
they went together without any problems 2 years ago.
1975 911S Targa
Silver Anniversary Edition
Old 01-02-2013, 04:29 PM
Bird. It's the word...
Fishcop's Avatar
If you're sending things to plater, include the calipers! Paint just doesn't look right and you've come this far. Zinc with a gold passivate finish was OEM. I did it all at home using a Caswell kit with some help from Eric (PMB) - he stocks the seals so you can safely split the caliper halves (they're cheap).
If you do a search for PMB here on the board you'll see some great results as well as a "how to" Youtube video.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-02-2013, 04:30 PM
Porsche Parts shows the seals to be P.N. 90135192810. Pelican stocks them, see P. N.
901-351-928-10-M33 and 901-351-928-10-OEM.
R/Dave
Old 01-02-2013, 04:51 PM
Garage Queen
PorscheGAL's Avatar
Fishcop, that is a great job with the plating. I'm still working on the process and maybe one day be at that level.
PMB did mine.
Before with worn caliper paint.
After
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 01-02-2013, 05:35 PM
Retired Member
Brian 162's Avatar
Here is my caliper re-finishing. I used VHT (Dupli-Colour) semi gloss spray paint. I painted them last year and so far the paint has held up.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-02-2013, 05:38 PM
The Dude abides...
bigel's Avatar
Originally Posted by PorscheGAL View Post
I especially like the blue powder coat on your fingernails...
But seriously, I love those before and after shots; it's just amazing to see the improvement side by side when the refinishing is complete.
'03 Carrera 4S
Old 01-02-2013, 05:59 PM
Project Addicted
I just ordered kits for my 3.2 front calipers and they include the seals. Cost was about 16.50 each. A real deal from an excellent guy. You do need a special bit to hold the bolts.mits called a Ribe bit
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 01-02-2013, 06:05 PM
wolds's Avatar
That settles it, I split the calipers and send everything off to New Jersey. So, lets see here. My wheels went to Harvey W on the west coast, my dashpad went to Classic 9 up North and these parts go to the east coast. Now I just need something heading south and I'll be set .
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-02-2013, 06:13 PM
80-911SC's Avatar
sonjay is in florida .. you could send him your deck lid and get a proper fitting duck for yourself ... plus you would get that south thing done ..........
Old 01-02-2013, 07:06 PM
wolds's Avatar
Thought I'd post some pictures of the final product. Assembly went well, just followed Eric at PMB's video. Finished them off by dusting them with a little VHT clear gloss caliper paint. They're gonna look good viewed through the Fuch's that Harvey W. is refinishing for me.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 02-11-2013, 09:43 AM
Local Mad Scientist
Andy911sc's Avatar
Did mine myself
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 02-11-2013, 10:06 AM
