-   -   Sprocket parallelism (http://forums.pelicanparts.com/porsche-911-technical-forum/83757-sprocket-parallelism.html)
logician 10-11-2002 12:18 AM
Hi,
Has anyone out there checked chain sprocket parallelism? I'd like to check the parallelism in my 930 engine, because I suspect a previous mechanic may have mixed up the shims. I've read the procedure and it looks pretty sensitive to errors. If you've got any words of wisdom on the procedure, I'd appreciate hearing from you.
Thanks!
-Juan
ChrisBennet 10-11-2002 01:01 AM
I've done it and you're right, it is sensitive to errors. I found it necessary to have an extra set of hands to hold the straight edge. Stomski Racing makes a tool so you can do it a little easier.
-Chris
RoninLB 10-11-2002 05:35 AM
I believe Pelican has a good inexpensive one..............Ron
http://www.pelicanparts.com/support/smileys/clap.gif
ChrisBennet 10-11-2002 05:58 AM
Ron,
I couldn't find it on Pelican. Here is the Stomski Racing one.
http://forums.pelicanparts.com/uploads/sprocket.gif
-Chris
RoninLB 10-11-2002 06:25 AM
thanks Chris..I gotta buy one before I open her up..................Ron
TimT 10-11-2002 02:50 PM
Ron, your rebuilding it?
RoninLB 10-11-2002 03:54 PM
No Tim..not rebuilding...Rudtner just did the final smog on the '77..and I got brand new E-cams in the closet..spoke to PMO on the Ride..anyway, as soon as I get my act together I gotta do the prep work..SSI/fume detector/Monty/Aircraft Spruce EGT system/MSD...the previous rebuild, 40k ago, saw 8.5 RS pistons/Raceware studs & rod bolts/Competition Engineering/etc..so I figure with 2 Big Rides and 10k of easy street driving/1 DE and it being tighter than a crabs a$$, and it being a carb eat carb world, I just gotta do it...I use 2 pocket warmers all winter...........Ron
http://www.pelicanparts.com/support/smileys/fles.gif
Wayne 962 10-11-2002 04:20 PM
The sprocket parallelism is tough to do, even with the engine out of the car. I recommend the Stomski tool in my new book...
-Wayne
GIBSON 10-11-2002 04:58 PM
It is tricky to measure, a true straight-edge is critical. I have a depth gauge that slips up against the straight edge and stays in place pretty well so I can get accurate readings.
I think it's important and worth taking some time to do it.
Here's my 73 set up to check the backspacing:
http://forums.pelicanparts.com/uploa...d9sprocket.jpg
speeder 10-11-2002 07:59 PM
Bruce, What did you use to get your cases clean? I have my motor out now, got it pretty clean w/ a steam cleaner, but want it to look like yours. Very nice. :cool:
304065 10-11-2002 10:41 PM
Parallelism
A former colleauge of mine decided to tear apart his 68 911S motor to put on some solid tensioners, and lo and behold, he found that the PO had installed the port cam sprocket backwards, e.g. with the cup facing forward. The port chain was cutting into the aluminum case and there were chips in the sump. So I would definitely make sure that the chain alignment is straight as a string: the Stomski tool is worth it, even one time.
