-   -   996 Turbo Tip Help! (http://forums.pelicanparts.com/porsche-911-technical-forum/837618-996-turbo-tip-help.html)
rhart 11-07-2014 02:30 PM
996 Turbo Tip Help!
996 Turbo Tip Help!
In order to afford a 996 TT I bought a car that had been hit damaging the right fender and right front suspension and mildly tweaking the left rear suspension.
The key would not come out the ignition so it was replaced. The key still is very difficult to remove and the gear shift is very hard to move back and forth taking two hands to force it into gear.
43,000 miles on the car. Any idea what has gone wrong with the tip and or gear changer? Everything else operates normally
Thank you
Bleedsblue 11-07-2014 02:36 PM
Wrong forum. You want this one: Porsche 996/997 Forum - Pelican Parts Technical BBS
rhart 11-07-2014 03:31 PM
It is on there as well but that forum gets very little traffic
scottrx7tt 11-07-2014 06:00 PM
You may wanna go to 6SpeedOnline. I used to have a 996 turbo tip car. I think those use cables to actuate the shifting of the transmission
rhart 11-07-2014 06:24 PM
Thanks Scott. I did post there but have not heard anything yet. I think you are right about the cables being a problem.
