petercoetzee's Avatar
Location: Cape Town, South Africa (if i buy any parts I ship to US address)
Gasket and bearing purchase advice -2.7
Hi Guys,
excuse my ignorance in this, but my 2.7 was a factory replacement case and has no number, so I can't figure out the year.
Its the red cooling shroud as pictured.
Im waiting on my engine guy to pull it apart so I know if its all std/std. In the meantime I would like to buy the gasket set and whatever else I can buy from pelican.
Is this the correct gasket set?
My concern is this in the comments :
By Yves st-georges, submitted June 2, 2014
Comments: Gasket for header to heat exchanger is missing. Have to be ordered separately.
Also Id like to buy whatever bearings i can in the interim without knowing the crank wear.
Am I correct in assuming the #8 bearing is standard regardless of whether the crank is under or over spec?
And does the same go for the #2 bearing shell? I can't seem to find that one on its own in Pelican?
Old 11-08-2014, 11:24 PM
bump for some help for a newbie.
Old 11-09-2014, 09:27 PM
